Spying on USB
JonnyMac
I have a friend with a machine (uP driven) that uses an Android tablet for control. They are connected via USB. I am working under the assumption that the Android tablet is the master in this situation.
Once coms is established, the tablet presents a UI for activating the machine. My friend has a custom accessory that he wants to attach. Ideally, he'd like to inject one of the button control signals into the machine without having to touch the Android tablet.
What I'm hoping for is a bit of guidance on how we might spy on the coms between the two devices. For the moment, I'm connecting either to my PC to see if I can get a response out of it.
As ever, you thoughts and input is appreciated.
JonnyMac
JonnyMac
If you have a logic analyzer with USB protocol analysis capability you could insert a cable breakout inline and tap the data signals.
If you prefer a software based approach, you could see if any USB sniffer software is available for the Android tablet. There are definitely options available for Linux and Windows, but I wouldn't be surprised if Android comes up dry.
Enjoy!
I did some tracing with the the P1 a couple of years back.
I will see if I can find it in my archives if you like? Won't be able to do this till Wednesday though.
or Micrisoft message analyzer: https://docs.microsoft.com/en-us/windows-hardware/drivers/usbcon/capture-and-view-ing-usb-traces-with-microsoft-message-analyzer-
But that is more for analyzing between device and pc
Aah, I knew I seen it somewhere: https://hackaday.com/2011/03/16/usb-man-in-the-middle-adapter/
[EDIT: add link to passive USB tap and remove it again]
He would like to be able to control this machine without using his tablet each time.
This is not a simple process. The table interface is simple enough but the commands that are exchanged between the tablet and the machine could be very complicated. It may even have a heartbeat being send back and forth to make sure the tablet hasn't gone to sleep and is no longer in control.
We need to know what the machine interface is doing. Either by getting the source to the application or specs for the machine. Trial and error here may break the machine.
Did you ever get this working?
Jim
