Activitybot C code for qti sensors won't run
Hi
We are having trouble loading code for qti sensors from the Activitybot C code folder (most recent version). We keep getting this error: simpletools.h: No such file or directory. We are using the most recent version of the Learn folder. Does anyone know how we can fix this?
thanks
Tom
It's having a problem finding the base include files.
#include "simpletools.h" #include "abdrive.h" // ------ Global Variables and Objects ------ int item; int left = 0; int leftPrev = 0; int right = 0; int rightPrev = 0; int driveLeft, driveRight; int scale = 1000; // Recommended speed at scale = 1000. // To make it go 1.25 times as fast, change scale to 1250. // To make it go 0.75 times as fast, change it to 750 // ------ Function Declarations ------ int getQTIs(int highPin, int lowPin); // ------ Main Program ------ int main() { drive_speed(0,0); pause(1000); drive_setAcceleration(FOR_SPEED, 2000); while (1) { QTIs(); switch (item) { case 0b1000: left = 0; right = 32; break; case 0b1100: left = 16; right = 32; break; case 0b1110: left = 32; right = 46; break; case 0b0100: left = 46; right = 64; break; case 0b0110: left = 64; right = 64; break; case 0b0010: left = 64; right = 46; break; case 0b0111: left = 46; right = 32; case 0b0011: left = 32; right = 16; break; break; case 0b0001: left = 32; right = 0; break; default: if(leftPrev > rightPrev) { left = 32; right = 0; } else if(rightPrev > leftPrev) { left = 0; right = 32; } else { left = 64; right = 64; } } driveLeft = scale * left / 1000; driveRight = scale * right / 1000; drive_speed(driveLeft, driveRight); leftPrev = left; rightPrev = right; pause(20); } } // ------ Functions ------ int getQTIs(int highPin, int lowPin); { set_outputs(7, 4, 0b1111); set_directions(7, 4, 0b1111); pulse_out(26, 230); set_directions(7, 4, 0b0000); pulse_out(26, 230); item = (get_states(7, 4)); //print("%04b\r", item); // uncomment to view in terminal }The first was the ";" after the function name (line 96 in SimpleIDE).
There should not be a semicolon after the function name in the function.
The next was line 30, the line before the switch statement
I think this should be I'm not sure what highpin and lowpin are in your program. I just used 7 and 6 to see if it would compile and it did.
I did not get an error
My version of SimpleIDE is 1.1.0, and I have the 1/23/18 library update.
Hope this helps
Tom
