Finch Robot... Really?
Just saw this $99 educational robot in a Make email. Interesting organic shape... The video says they designed it from 4 years of user input. Yikes. Three obvious objections:
1) Tether required! USB powered, no battery on board. Someone thinks a battery is more trouble than a tether. Really?
2) They show a smart phone controller. What, now I plug the tether into my smartphone and drain that battery? Or tether to a Powerbank and hope for the best? Or use a laptop plus a smartphone?
3) Pen mount is far behind the wheel axis. No idea how you're supposed to draw with that.
"Birdbrain Robotics" (seriously) claims the robot is engaging and rich in other features, but they lost me with these two. Now I know very little about robotics, but it appears that they combined the worst of several concepts without compromising any of the shortcomings.
Give me an S3 any day. Heck, give me an original blue Scribbler 1 any day!
https://www.makershed.com/products/finch-robot
We'll have to see. Four years of development, and it's from CMU -- a pedigree worth at least considering. Their video needs at least a brief glimpse of the programming interface, though. The physical robot is only half the story.
(I had to chuckle when seeing the wheels. Anyone with a vintage BOE-Bot will recognize the basic look ... a machined white disc with an o-ring around it.)
Same as my 1998 Growbot:
(1. The pen is mounted to the back of the bot, and would often cause more or less drag, deforming the letters
(2. The tether cable was quite heavy (USB-B) and had to be awkwardly held up to prevent it from exerting any outside force on the bot
(3. The pen holder isn't really a holder at all, but a half circle on the back of the bot. The pen had to basically be taped to the bot, which could come loose, as the tail was too tapered to allow the tape to be properly wrapped.
I'm not sure the program was ever used for demo purposes, but then again, I can't remember the last event these were demoed at.
But hey, you can control them with Java code, which is where the real priorities lie.
Does not appeal to me. From an engineering perspective or aesthetically.
Erco, they stole our idea for FlounderBot!
https://en.wikipedia.org/wiki/Flounder
