TTL computer
https://gigatron.io/
Just found this while trolling youtube. A computer using ttl logic in place of a cpu.
-dan
-dan
If we believe what it says then the TTL computer is faster and smaller than the 8 bit machines that were all the rage. Like the Apple 8 bitters.
If so, why did anyone use an 8 bit CPU back in the late 1970's ?
2. Cheaper
Given the price of 8 bit CPU's at the time I can imagine that board of TTL would have be cheaper as well.
I don't know what to make of the guys claims.
Of course, what the microprocessor sold us at the time was ease of programming. I suspect that TTL machine does not win there.
It also has just 7 core opcode groups, with mode modifiers, so code efficiency is not great.
If it can run old games, that's not doing too bad...
I do wonder if those big ROMs were available at the time for the decode logic.
7 core opcode groups might make it a RISC machine. Ahead of its supposed time!
IIRC there were no standard programmable roms of that size or width at the time. There were small (~1K - 256x4, 128x8) one time proms around. Of course things were changing so fast that what was available changed from month to month so "at the time" had to be a pretty specific year and month.
Would there be any interest in a microprocessor kit that consisted entirely of TO-92 transistors? Apx 300 transistors to be soldered. They are arranged in a 17 x 17 monolithic grid. (A handful of resistors hidden on the underside of the board)
Of course, like the monster6502, there are through-hole LED's intersped among the transistors.
Obviously a 300 transistor microprocessor would be very, very simple: 4 bit, 5 instructions. But enough to run usefull demo programs. A socket on the board to plug in an EPROM with your program.
You would need to be masochist to solder than many TO92, to end up with something that can't even tell the time...
Actually, look up CP-642B for a look what was done with only transistors.
Back in 1980 when I started work for Marconi Radar they still had a Marconi Myriad minicomputer working in a back room. Built from transistors.
Looks like it was decommissioned the year after I left:
http://www.computinghistory.org.uk/det/43525/Marconi-Myriad-Photographs/
