3D Printers
Hello All,
Just took another step. Ordered my first 3D Printer, yes I did use one OFF an ON at the now (Out of Business) local Tech Shop for just over a year. I currently want to update an old Case for my new PCB and then I was presented with a new project and I've built the 1st Enclosure out of card board and now I know what I want for the 1st prototype.
Did my research from Youtube and found what I wanted to buy and had the Credit Card out to get the Dremel 3D 40. Then I found the Dremel 3D 45 and was even more sold. The price was way over for the actual working product that you would get though. The extra bells and whistles I was just going to bite the bullet on. I then took 2 weeks off from researching (family things, relearning Autodesk inventor and getting my new RS232 Scanner working properly). Thanks Chris.
Further research has lead me to the QIDI Tech 3D 3DP-QDA16-01 Dual Extruder printer by QIDI TECHNOLOGY, purchased from WalMart with their 4 yr $105 extended warranty for a total of$910. Six (6) to 12 days to deliver though, free shipping. It may be a bit over kill but this will push me even more and way cheaper then the Dremel.
If anyone has comments on this printer or family of printers please let me know. I will be needing ALL the feed back and help that I can get. Lots of Youtube.com videos and the 2 week break has lead me to this printer.
Thanks for any feed back.
I think most of the printer are the same. They all deposit plastic based on a stepper motor.
My first unit came as a kit and I was happy with that as it was also open sources so I can see how it is all done.
For me the main thing now is print area. Some parts require a good print area and mine just falls short in that area.
The nice thing about a Prusa is the metal bed. I fight to get my parts off the bed of the printer and this makes it a no brainer.
Check it out here: https://shop.prusa3d.com/en/3d-printers/180-original-prusa-i3-mk3-kit.html#
PS: my first printer costed $220 shipped.
It sticks very well and when the print is done, I can take it off (it is held on with those springy paper clips) and flex it to get the part loose.
I only print PLA because I don't have a heated bed.
Bean
Apart from printing stiffening brackets, filament holders, etc., to improve the performance, the best thing I did with my 3D printer (an Anet A8) is by a "Lack" table from IKEA (£10 delivered!) and fix the printer to it, making sure it was 100% square and even. The extra rigidity stopped some of the wobbles and I can move the printer without worrying too much about it going out of square.
Some of the cheaper motherboards have rather weedy (and non-replaceable) regulatorswith a tendency to 'let out the magic smoke'. There are lots of cheap MOSFET boards out there to take the strain and these are much cheaper than new motherboards.
I live in a house that seems to have a constant 'snow' of dust ( I don't know why!). After a while, the tiny amounts of dust on the filament built up and clogged the nozzle, so I added a filter. Putting the spool under the Lack table also helped.
A good guide to troubleshooting can be found here.
