Propeller Backpack - No NTSC Video Output - text works — Parallax Forums
micromucmicromuc Posts: 11
edited 2018-03-19 21:36 in Propeller 1
I'm trying to overlay text on top of incoming video. I am getting the numbers on the screen from my program but the video signal is not making it to the output. Jumpers VID and OVL are installed. I've attached pictures of a few different test points on the board. Pictures are labeled, Video Input, Video Output, Prop pin A22, Prop pin A19, Prop pin A11. Hopefully someone can help because I'm out of ideas. Thanks...Mark
The Code that works at putting numbers on the screen:
pause 50
    TextOut = 0     'Reset the Propeller Backpack
    pause 500
    TextOut = 1
    pause 2000      'Wait for it to come out of reset
    counter = 1
main
    SEROUT2 TextOut,84 + 32768,[dec counter,$01]    '9600 open-drain, $01=move to current screen home position
    pause 1000
    counter = counter + 1
    if counter = 1000 then counter = 1
goto main
