Wireless power method? 5vdc
Have you guys seen a device to power a prop PCB with 5vdc wirelessly/non contact? I want to mount the fixed part of the power transfer to a panel and have it’s “receiver” part mount on a sliding system. When the Receiver slides under the fixed part it can provide power wirelessly to the prop board. I assume that this is two coils with one sending a frequency and the other receiving the magnetic source and outputting an AC voltage that can then be rectified.
Transmitter: https://www.adafruit.com/product/2162
Receiver: https://www.adafruit.com/product/1901
I believe T Chap's acronym was referring "volts direct current", not "very dangerous cage"
https://www.mouser.com/search/refine.aspx?Keyword=426-DFR0362
They seem to have a bit better range and tolerate off-alignment better than the adafruit ones. These are the best ones I've found so far
Wow! Plug-and-play transmitter and receiver for $7? Nice! And It looks like they put out 1A instead of 500mA.
