calibration problems — Parallax Forums
I have calibrated my activity bot and keep getting the error message that my batteries are dead or the jumper booster is still on the 5V. My batteries are brand new and the jumper is on the VIN and not the 5V. What can I try to fix it?
    edited 2018-02-10 15:59
    Your other posts have been deleted as cross posting is not allowed. I left the post in Robotics as it seem the most appropriate.
    No Cross-Posting:
    Cross-posting is: 1) submitting a post to one forum or thread, and then submitting a second linking to the original post (without changing content or intent), or 2) creating an identical post in more than one forum or thread. When the same content is found in more than one post, even under different subject lines, the forum moderator will remove one (or more) of the redundant posts and the posting account may be subject to moderation.
  • WhitWhit Posts: 4,194
    RollTideKid11,
    Question 1 - Activity Bot or Activity Bot 360? See - https://learn.parallax.com/tutorials/robot/activitybot/blocklyprop-robotics-activitybot/build-activitybot/hardware-check
    Question 2 - Have you tested the battery voltage?
