Converting Audrino C code to Parallax Issues..
                                  in Accessories
                    I'm trying to convert the audrino c code example for Rfid read/write, but am having some issues in the conversion. This is what I have..
the issue I am trying to solve is: serial_open
I'm not sure how to calll the function:
Can someone give me a hand..
Thanks ahead of time..
It looks like you are trying to use the Parallax RFID Read/Write module (#28440) on the Propeller in C.
I noticed that the Arduino code you translating was a translation of BS2 code and someone placed a Spin translation in OBEX but the only C code appears to be for the Arduino or just the Reader.
One of the C gurus should be able to help you out.
The code will build as an RFID demo program that you can use as a basis for your project...
Here's the top file of the librfidser project, which when built as non-library creates a test harness for the RFID module (#28440):
/* librfidser.c Test harness for rfidser library. Enable -> P2 Sout -> P1 */ #include "simpletools.h" // Include simpletools #include "rfidser.h" // Include rfidser int rfidEn = 2; // Reader /ENABLE pin int rfidSout = 1; // Reader SOUT pin rfidser *rfid; // Set up device ID int main() // Main function { rfid = rfid_open(rfidSout, rfidEn); // Open reader, start reading while(1) // Main loop { char *str = rfid_get(rfid, 1000); // Wait up to 1 s for card if(!strcmp(str, "timed out")) // Timed out? print("No ID scanned.\n"); // display "No ID..." else if(!strcmp(str, "70006E0299")) // Round card ID match? print("Round card.\n"); // diaplay "Round..." else if(!strcmp(str, "0200822A14")) // Rectangle card ID match? print("Rectangle card.\n"); // diaplay "Rectangle..." else // No matches? print("id = %s.\n", str); // print ID. } } /** * TERMS OF USE: MIT License * * Permission is hereby granted, free of charge, to any person obtaining a * copy of this software and associated documentation files (the "Software"), * to deal in the Software without restriction, including without limitation * the rights to use, copy, modify, merge, publish, distribute, sublicense, * and/or sell copies of the Software, and to permit persons to whom the * Software is furnished to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER * DEALINGS IN THE SOFTWARE. */dgately
You can do this in Blockly or switch to the "code view" and see the resultant C code.
I convert the code as close as possible to the original code but there is some bad coding in there to start with which I was not going to fix and I don't have that device to test that the changes I made actually work.
I switched to fdserial as it has functions close to what is need by Arduino.
While I have converted serval devices from Arduino over to Propeller I generally start over and write from scratch.
