74hc595 seven segment.
in Propeller 1
I picked up some 7 segment modules off ebay. https://ebay.com/itm/74HC595-static-drive-2-3-4-segment-digital-display-module-0-5-inches-2-3-4-way/332337987430?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
They use the sm74hc595d chip.
Any data sheets I found were not in English. Not sure if they can do 3.3v logic.
Has anyone worked with these?
These are how they labeled the pins.
If i had all the segments on. Some of the segments would turn on when testing. Not sure what I'm doing wrong.
I don't have any level shifters around. Might have to order some.
IT's to big to post here so I'll attach it.
Looking at your code, you are doing everything exactly right.
Also, the really good documentation in 74HC595_Regular makes me think it was probably tested and likely works.
I would try to decide whether it is a hardware (wiring) vs software issue.
I would write a really simple (trivial) spin program to shift out a few bits, followed by a low-to-high transition on Latch_Pin.
If something lights up, you got a software issue.
I had a flip module show up. So set that up a new bread board with some solid jumper wire.
Working as expected now. Must have been my previous wonky set up.
