Input voltage on 32212 Proto Board
MSDTech
in Propeller 1
I know the documentation states the input is 6-9VDC, but I would like to use a 12VDC input. The specification for the LM 1086-5.0 states that it has an input max voltage of 25V. The total power draw will only be needed to power the propeller, all other circuits will be running of a separate 5V supply. Is there any problem with using the 12V supply.
