No Propeller Chip Found On Any Serial Port
in Propeller 1
I just received the two Propeller Flip Microcontroller Modules that I ordered a few days ago. When I choose "Identify Hardware" from the Propeller Tool menu, I get a message that states that "No Propeller Chip Found On Any Serial Port". I get the same results with both modules. When I plug in a Propstick USB, everything works fine. Did I get two bad modules, or am I missing something?
Also... if you're using a hub, try plugging FLiP direct to your pc. And if that doesn't solve, try unplugging other usb devices in case one is taking more power than the pc expects.
