Looking for a format...
in Propeller 1
I was wondering if there, or someone has, a format to follow, in SPIN that will load a program in COG0, then/also load 7 different programs in COGS 1 through 7. The programs in COGs 1 through 7 will do there own thing, constantly computing a VARIABLE and then putting it in the HUBS RAM for the first COG (COG0) to in turn constantly display on an LCD the VARIABLE values...
Perhaps a better word for format, would be a templete.
Hope this isn't too silly of a question...thank you...DennO
What exactly is it that you are trying to do because do you really need every Cog to be doing something?
Here is a program that talks to all the Cogs, if you don't mind a little wiring.:
http://obex.parallax.com/object/61
Not sure if it is what you were looking for.
When you load Spin code to a Propeller it runs in COG 0. So nothing special to do there.
You can then start a method from any Spin objects you have written on COGS 1 to 7. This is all quite normal Spin programming.
By way of "template" pretty much all the objects in obex are such templates. As is any other non trivial program you find on the forum and elsewhere.
IIRC there is a demo led flashing multiple cog program that comes with the PropTool program. Think it's in the exercises folders.
Attached is an example that (hopefully) illustrates what you're asking. Each cog runs its own method of a simple repeat loop, updates its own VAR, and the main cog displays each var on a Parallax serial LCD (#27976, #27977, #27979).
Cheers,
Jesse
And, thanks to all for your help...has anyone worked with the new FLIP from Parallax?
DennO
Strange...I just tried to download and unzip it just to verify and it seems okay here. I'll try attaching the individual files.
How are you reading the temperature?
Are your probes "smart" or are you using a chip such as an ADC to get temperature readings.
If you are just periodically reading each probe in order then I don't see why this couldn't be done with just 1 Cog.
In the book Parallel Processing with the Propeller Microcontroller, there is a PASM (Parallax Assembly) program that reads a 2-Channel ADC on 1 Cog and feeds the values to a Spin program.
I think that is what you are trying to do.
If you don't need the temperature often, say every 30 seconds or a minute, then Spin itself should be more than fast enough to get your readings.
The Propeller is considerably faster and more powerful than the BS2sx.
Actually, if you want, you can use one of the standard video drivers to print the readings on a TV or a VGA monitor, and still have a few Cogs to spare.
I know that TV_Text is very easy to use and functions similar to DEBUG.
Then...
