Hydra resources/basics
in Propeller 1
Hi,
A while back I picked up one of those Hydra game stations, for the intent to learn a little about ide programming/basic game design.
I searched a bit here and there and it seems a while back the Hydra forum was asimulated with the prop 1 forum.
Can someone point me in the direction of these old threads? Or does no one use the Hydra anymore?
If that's the case, can I pull the prop1 chip out of the Hydra and stick a newer C3 in there?
Anyways.. cheers
V.
Anyways.. cheers
V.
You might try here though:
forums.parallax.com/discussion/126654/merge-the-hydra-forum-with-the-propeller-forum
forums.parallax.com/discussion/108626
I noticed that the creator of the Hydra:
http://www.ic0nstrux.com/hydra-game-development-kit#.WjadfFVKvct
has a forum, but no entries:
http://www.ic0nstrux.com/forum/
They also designed the C3.
The Propeller MCU is identical on the Hydra and C3, but in a different physical form factor. DIP vs SMD.
If you type HYDRA in the search box in the upper right of the forum software, you will come up with a lot of hits.
Probably thinking of maccas's P8X system:
http://forums.parallax.com/discussion/164043/the-p8x-game-system#latest
Massimo
Edit: it should be this one..
https://www.parallax.com/sites/default/files/downloads/32360-Hydra-Game-Dev-Manual-v1.0.1.pdf
