ActivityBot 360 upgrade?
David Betz
in Robotics
What is the difference between the original ActivityBot and the new ActivityBot 360? Is it just different servos? Can I upgrade my old ActivityBot simply by purchasing two of the 360 servos?
EDIT: As long as you use the 360 Learn pages.
https://www.parallax.com/product/32612
Batteries ARE included!
Batteries alone can be fun.
Your regular ActivityBot can become an ActivityBot 360° by swapping the servos and removing the old external encoders. You'll also need to remove the 20k-ohm resistors on P14&P15.
Be sure, like Jim said, to use the AB360 tutorials/images/libraries instead of the regular ones (where specified).
