Can the 2N2222A be substituted for the 2N2222
I see a lot of Stamp related circuits specifying a 2N2222 transistor.· The 2N2222 is very difficult/impossible to find - here in the UK, at least.· The 2N2222A is very easy to obtain and very cheap.· Can the 2N2222A be used instead of the 2N2222 ?
A 2N3904 will "work," too.
Go for it.
Chris Savage
Parallax Tech Support
Generally the 2n2222 is more able to handle higher power than the 2n3904, but can replace the 2n3904 in just about any circuit. So don't bother to buy both.
A lot of transistors are 'swap-able'. You can really struggle to get exactly the same number when there are likely to be a dozen of similar ones that can do the same job.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
If you are planning to work on 2n2222, then you must have a look at Introduction to 2n2222. I have shared detailed overview of how it works and have also shared its working Proteus Simulation.
Thanks.
BTW, this post is 10 years old, so don't let it dampen your enthusiasm to help if the OP is long gone.
Your site has several other interesting pages, I look forward to checking it out over the break when I have more time.
http://www.analogzoo.com/2015/03/beware-the-p2n222a/
