How do I prevent the propellor from restarting when a serial program closes?
in Propeller 1
I'm using ubuntu. Is there a way to prevent that by, changing something on the propeller or on the program settings?
If so have you tried making it on different pins?
And what's the circuit... Custom or Parallax board?
Sadly,
In your icon, green varies vertically and red varies horizontally. How is blue calculated?
Oops! Didn't mean to highjack the thread; the devil made me do it.
EDIT: Hmmm... I just noticed in the schematic that the enable for U14 and U15 buffer is not connected to anything or is a no-connect ... it should be connected to the +3.3V from the USB power to enable it when USB power is applied. ... it's possible it has an internal pullup however
RevA:
RevB,C
