Trouble with node js serialport.parser and PST...
Copper
in Propeller 1
I'm having some trouble with node js serialport.parser
I have a dead simple program (HelloPST basically) running on my prop dev board just spitting out "This is a test message!" over and over...
I tried using FullDuplexSerial since PST says in the comments it's "for the parallax serial terminal" (didn't help)...
I tried slowing down the data rate just because...
on the server, the port opens successfully, and if I register a 'data' event with the port I get:
port open.
port data:
port data: T
port data: his
port data: is
port data: a
port data:
port data: te
port data: st
port data:
port data: m
port data: e
port data: s
port data: s
port data: a
port data: g
port data: e
port data: !
port data:
but the parser's 'data' event never fires (should with new line; tried adding '\n' to message just in case, but no effect)...
server code for serial port stuff:
based on Heater's post/thread from 2013
http://forums.parallax.com/discussion/147253/node-js-and-the-propeller
and the node serialport documentation
https://github.com/node-serialport/node-serialport/blob/v6.0.4/README.md
my node js version is v6.11.3
I'm afraid I don't know what to try next... I would appreciate any suggestions...
''This code example is from Propeller Education Kit Labs: Fundamentals, v1.2.
''A .pdf copy of the book is available from www.parallax.com, and also through
''the Propeller Tool software's Help menu (v1.2.6 or newer).
''HelloPST.spin
''Test message to Parallax Serial Terminal.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
pst : "Parallax Serial Terminal"
''pst : "FullDuplexSerial"
PUB TestMessages
''Send test messages to Parallax Serial Terminal.
''pst.Start(115_200)
pst.Start(9600)
''pst.Start(31, 30, 0, 115_200)
repeat
pst.Str(string("This is a test message! \n"))
Pst.NewLine
waitcnt(clkfreq + cnt)
port open.
port data:
port data: T
port data: his
port data: is
port data: a
port data:
port data: te
port data: st
port data:
port data: m
port data: e
port data: s
port data: s
port data: a
port data: g
port data: e
port data: !
port data:
var serialPort = require('serialport');
var serOptions = {
baudRate: 9600,
databits: 8,
stopbits: 1,
parity: 'none',
buffersize: 256,
encoding: 'utf8'
const readLine = serialPort.parsers.Readline;
const port = new serialPort('/dev/ttyUSB0', serOptions);
const parser = port.pipe(new readLine({delimiter: '\r\n'}));
parser.on('data', function(data){console.log('parser data: ' + data.toString('utf8'));});
//port.on('data', function(data){console.log('port data: ' + data.toString('utf8'));});
port.on('open', ShowPortOpen);
port.on('error', ShowError);
pst.Str(string("This is a test message!",10))
Edit: \n = 10, \r=13
