Thermistor Cable Harness Tester — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,940
edited 2017-11-16 17:56 in Customer Projects
This is still a work in progress, but since I made a lot of headway in the last week, I just had to post some pictures and details. I am making a custom test fixture for some cable harnesses we build at work.
Scope of Project:
The proto board will be in the enclosure with the display mounted in the top of the enclosure. The 2x7 connector will be on the front side facing the operator so that the adapter cable with the spring pins is easy to get to. There will be a set of "keys" on a key ring that will correspond to each cable assembly part number. When powered up, a bootloader program from the onboard EEPROM runs and the display will prompt for a key to be inserted into the 2x2 connector on the side. Each key connects an EEPROM so that the programmer has a specific configuration program. With a key inserted, the display will show "ready to test Part Number XXXX with X thermistors", and the test loop begins. The test loop consists of the following steps:
1) Read on board thermistor value as reference .
2) Read thermistors on 2x7 connector per key.
3) Compare values using appropriate tolerance.
4) Light the 7 LEDs appropriately (green=pass, red=fail, off=NA)
5) Display results on screen (IE: "All Pass" or "CH2 Fail High")
6) When the harness is removed and all readings are infinite, display will show the ready message again.
7) If the key is removed at any point, the tester will exit the test loop by rebooting to the bootloader code prompting for a key..
Attached are pictures of the prototype unit and a graphical representation of one of thermistor cable configurations we build (this one is 7 thermistors with 2 interconnects)
    edited 2011-02-17 20:40
    I was finally able to get some shots taken for an update. Here are some pictures of some of the wiring.
    Details:
    **RC Decay occurs on P0-P7. P0 is a reference thermistor (the little black bead looking thing next to the yellow cap on P0). P1-P7 have caps on the PCB, but run out to the 14 pin Molex MicroFit panel mount connector where the thermistor harness attaches for testing.
    **The 7 Bi-Color LEDs are banked using P11-P17 for one side and P21-P27 on the other side. This enabled me to "dumb down" the code for when I start making different configurations. 220 Ohm resistors are placed from the P21-P27 side and then red 26AWG is used to run them to the suface mount header positioned above P11-P15. On the backside, short jumpers feed over P16 and P17 to the header. The bi-color LEDs have Molex SL series 2 pin connectors to connect to the header.
    **The LCD is connected to P8 on one of the servo headers and tied it's Vdd is tied to 5 volts with a jumper wire.
    1024 x 463 - 133K
    942 x 768 - 155K
    1024 x 641 - 179K
    1024 x 759 - 290K
    803 x 768 - 296K
    768 x 881 - 223K
    866 x 768 - 262K
    1024 x 722 - 259K
    edited 2011-02-17 20:41
    More details and code:
    My code is not finished, because I will eventually be using a bootloader and loading specific configurations from an "EEPROM Key". However, this test code attached enables me to use the tester for a specific cable assembly with 7 thermistors. The code is thoroughly commented.
    Any feedback on code is welcome, even criticism.....
    Andrew Williams
    4/25/2011, Version X14
    This code started with the RC Decay lab from Propeller Education Kit and is used
    to test a cable harness consisting of 7 thermistors. The RCDecay loops simply test
    each thermistor and store the result in an array. Then, a display loop presents
    the results on Bi-Color LEDs and a 2x16 serial LCD.
    X01.....Setup for Pin13
    X02.....Setup for two separate Pins with two pubs
    X03.....Setup for variable for pin 12
    X04.....Setup for repeat loop, but dead
    X05.....Setup for repeat loop, dead after removing Main2 (missing master repeat)
    X06.....Cleanup working 2 thermistor code
    X07.....Add BiColor LED
    X08.....
    X09.....Added settle time
    X10.....Renumbered for Proto board and 7 thermistors
    X11.....Added PST and loops for LEDs, tested without ref thermistor
    X12.....Added ref thermistor and fixed code to final therm configuration
    X13.....Added LCD and some comments
    X14.....Commented out PST, fixed LCD display runovers
    CON
      _clkmode = xtal1 + pll16x                  ' System clock → 80 MHz
      _xinfreq = 5_000_000
      LCD_PIN   = 8                              ' for Parallax 2x16 serial LCD on P8
      LCD_BAUD  = 9_600
      LCD_LINES = 2
    Var
      byte   NumErr
    OBJ
      lcd : "Serial_lcd"                         '2x16 Serial LCD
    '  pst : "Parallax Serial Terminal"           ' Use with Parallax Serial Terminal to
                                                 ' display values
    PUB Init
    '  pst.Start(115_200)                             'Start Parallax Serial Terminal
      main                                           ' Call the Main method
    PUB Main | time[8], thermpin
    dira[11..17]~~                                    ' set 1st LED pin (P11-P 17) as outputs (green c
    dira[21..27]~~                                    ' set 2nd LED pin (P21..P27) as outputs
    if lcd.init(LCD_PIN, LCD_BAUD, LCD_LINES)         ' start lcd
          lcd.cursor(0)                               ' cursor off
          lcd.backLight(true)                         ' backlight on (if available)
          lcd.cls                                     ' clear the lcd
          lcd.str(string("P/N 47-0838-001", 13))      ' Put cable part number on first line of LCD
          waitcnt(clkfreq + cnt)                      ' Pause 1 second
    repeat
        numerr := 0                                   ' clear error count for test loop
        lcd.clrln(1)                                  ' clear 2nd line of LCD
        lcd.gotoxy(0,1)                               ' move to first space of second line
        lcd.str(string("TESTING."))                   ' write to LCD
        repeat thermpin from 0 to 7                   ' check all thermistors, including reference at 0
          lcd.str(string("."))                        ' write a "." to LCD upon each thermistor as a progress line
                                                      ' Configure counter module.
          ctra[30..26] := %01000                      ' Set mode to "POS detector"
          ctra[5..0] := thermpin                      ' Set APIN to thermpin
          frqa := 1                                   ' Increment phsa by 1 for each clock tick
             waitcnt(clkfreq/1_000 + cnt)            ' Settle time
             dira[thermpin] := outa[thermpin] := 1    ' Set pin to output-high
             waitcnt(clkfreq/100_000 + cnt)           ' Wait for circuit to charge
             phsa~                                    ' Clear the phsa register
             dira[thermpin]~                          ' Pin to input stops charging circuit
             waitcnt(clkfreq/300 + cnt)               ' Allow time for discharge
             time[thermpin] := (phsa - 637) #> 0      'Adjust ticks between phsa~ & dira[thermpin]~.
             waitcnt(clkfreq/8 + cnt)                 ' quick pause
     ' pst.clear                                      ' clear the PST window
      repeat thermpin from 1 to 7                     ' repeat LED/LCD results for 7 thermistors
        'pst.Str(String(pst#NL, "Time "))             ' Show Time in PST
        'pst.Dec(thermpin)                            ' and thermistor number
        'pst.Str(String(": "))                        ' and colon
        'pst.Dec(time[thermpin]-time[0])              ' and difference between ref therm 0 and current thermistor
        if time[thermpin] - time[0] > 22000 or time[0] - time[thermpin] > 22000  ' if thermistor is different by more than 22000 from ref
           numerr++                                   ' increase the error count
           outa[10 + thermpin] := 0                   ' set thermpin LED for Red cathode
           outa[20 + thermpin] := 1                   ' set thermpin LED for Red anode
           if thermpin > 6                            ' determine position for result on LCD (thermistor positions are physically: 7,1,2,3,4,5,6)
             lcd.gotoxy(0, 1)                         ' goto leftmost position if thermistor 7
             lcd.str(string("F"))                     ' mark as a fail
           else
             lcd.gotoxy(thermpin*2, 1)                ' if 1-6, go to position equal to 2x thermistor number
             lcd.str(string("F"))                     ' mark as fail
        else                                          ' if thermistor is within tolerance to ref....
            outa[10 + thermpin] := 1                  ' set thermpin LED for Green anode
            outa[20 + thermpin] := 0                  ' set thermpin LED for Green cathode
              lcd.str(string("P"))                    ' mark as pass
            else
      if numerr > 0                                   ' If any errors
        lcd.gotoxy(15,1)                              ' goto to bottom left of LCD
        lcd.cursor(3)                                 ' and blink the cursor
      else                                            ' If no errors
        lcd.cursor(2)                                 ' and hide the cursor
      waitcnt(clkfreq * 2 + cnt)                      ' leave results up for 2 seconds
        outa[11..17] := %0000000                      ' Turn Off LEDs
        outa[21..27] := %0000000                      '
    edited 2011-03-07 15:12
    3/7/11 Project Status: The "secondary EEPROM" bootloader is in its final stages (on this thread) which will provide the "key" functionality that will drive the various configuration programs. I have also completed making all of the crimped wire leads for the connectors and LEDs. The LCD is using a basic 3 pin servo extension cable. The case went through a few modifications to enhance it's usage and everything looks really good. I should be packing it all together in the next few days. Only thing left is to expand my development code to include all 7 thermistors (right now it only does 2) and add the LCD routines.
    edited 2011-03-29 17:11
    WBA - looks great!
    Actually, with such a great looking case though, it doesn't look much like a "prototype" - well done!
    -Matt
    edited 2011-03-30 17:39
    Matt, Good point. This is actually Version 3 of the case. The first one, I had the dimensions a little snug for the LCD thinking it could be wedged in, but acrylic is not easily persuaded. During V2, I broke two of the pieces trying to force the panel mount connector into the lasercut hole (I took off my engineering hat while I tried to do that apparently) So the enclosure in the picture is technically the 3rd go around.
    Since Parallax offers a laser cut case for the proto board and publishes the drawings with it, prototypes do look more like finished products. So I agree with you in how much nicer it looks compared to my other "prototypes". I should have more pics over the next few days as I hope to spend some of my birthday weekend (4/1) on Propeller projects. The code is about half done and I have a couple EEPROM keys made up already. I also need to make an EEPROM key programmer.
    edited 2011-04-25 17:28
    I just updated the 2nd and 3rd posts with details and pictures. The final tester will hopefully be complete this week once I get additional plastics and finalize the code for the secondary EEPROM functionality. (Acrylic and I don't quite get along as apparent by the broken pieces on the current box, I must not know my own strength)
    To-Do list as of 4/25:
    1) Another set of plastics cut.
    2) Wire up EEPROM Key connector
    3) Wire up power switch.
    4) Setup code for bootloader/secondary EEPROM functionailty
    5) Figure out how to load programs to a secondary EEPROM without using a socket.
    6) Decide on power source (I may just use a wall wart now since the inside is a little packed and each bench has power anyways)
    7) Fully document for a Customer Applications Submission to Parallax
    edited 2011-05-11 16:03
    Most everything is complete and working well. I added the wiring for the EEPROM key Connector, modified the DC Jack to use the power switch, replaced the few broken case pieces (the partially assembled case didn't travel well while being tossed around in my bookbag back and forth to work and home)
    For the DC jack mod, I cut off the back tab (positive center tab) just above the bottom edge of the jack. Then I soldered on a surface mount two pin header with one pin up towards the center pin and the other pin down so that it would fit into the hole for the original pin. This created a place to connect my panel mount power switch's 2 pin AMP MTA connector. The proto board's power switch is left in the full on position. If I want to bypass my panel mount switch, I can just put a jumper shunt across this 2 pin header.
    The 4 pin Molex EEPROM Connector is connected to P28/P29 and 3.3v/GND and the EEPROM has a pullup on the A0 pin. The current EEPROM key is made from a piece of perfboard, a DIP8 socket, and a DIP8 32kb EEPROM. I will be making future keys with a surface mount SSOP8 and a SSOP to DIP8 adapter board to keep the height to a minimum. I am also working on an acrylic housing to make it like a key fob.
    When the unit is turned on without an EEPROM key, the LCD says "Searching for Key..." and then after a second, changes to "KEY NOT FOUND, restarting...". While that is displayed, the LEDs light up one at a time and then the bootloader program restarts.
    Anytime the EEPROM key is plugged in, the EEPROM key program is loaded during the "Searching for Key..." step.
    When the EEPROM Key program runs, it displays the cable part number on the top line of the LCD and "testing..." on the bottom line. The RCDecay loops run and then the second line of the LCD will display a P or F for each of the 7 possible thermistors and the LEDs light red or green respectively.
    For my debugging, I made a sample 7 thermistor "harness" that is only a couple inches long from 7 of the thermistors used on an actual harness.
    All that is left is to solder the 2 pin header for the power LED (I forgot that) and make more EEPROM Keys.
    Now to do the formal write-up for the customer apps section of Parallax.......
    824 x 768 - 189K
    1024 x 585 - 172K
    1024 x 732 - 227K
    1024 x 554 - 173K
    775 x 768 - 234K
    1006 x 768 - 281K
    1024 x 535 - 106K
    edited 2011-05-21 11:46
    Tester is completed and being shown at UPEW!
  • Wow, can't believe it's been over 6 years since I made this. It is still in use by our production team at work for the cable harnesses for our customer. I had to fix the LCD last week as the hot melt had come loose from the top cover, but otherwise, still working fantastic!
  • I am sort of confused how you soldered the resistors at P21,P22,P23, aren't the pads you use for the resistors connected together anyway?
    edited 2017-11-16 21:15
    msrobots wrote: »
    I am sort of confused how you soldered the resistors at P21,P22,P23, aren't the pads you use for the resistors connected together anyway? Mike
    Wow, you are exactly correct. I am one set of holes off, so my inline current limiting resistors are doing absolutely nothing. Great catch! Obviously hasn't caused issues, but not working as I designed.
  • Hilarious. Good catch Mike !
  • Great project, awesome pictures!
