TM34dz temp gauge with BS2
Nomadic0
Hey guys, in testing my temp chip, I wanted to know why I am getting a reading of 40 (room temp) for my temp gauge. I have it set up (with the analog to dig converter) like the pot in page 45 of this doc
https://www.parallax.com/downloads/basic-analog-and-digital-text
I am also using the sample program below it (but using DEC instead on BIN8)
On the bright side, it is reacting positively to heat
To keep it simple, each bit represents 19.53 millivolts. That is 5000 millivolts reference divided into 256 steps. So, one bit represents about 2°F and 40 bits (as you found) represents about 19.53*40 = 781 millivolts or 78.1°F. You'd be pretty close by multiplying the binary value times two to get °F.
There more accurate ways to do the math. The text shows one, here is another: The */ operator implicitly divides by 256, so the result comes out the same as if it were (for example) degF = 40 * 5000 / 256 = 781. The Stamp can't compute 40 * 5000 directly because of the 65535 limit of a 16 bit word, but */ gets around that.
I was also looking around and have failed to find a way to display a decimal in a DEBUG statement
Is this possible?
I appreciate all the feedback
In the example where answer is 781 millivolts representing 78.1 °F, You could do as follows:
DEBUG DEC milliVolts/10, ".", DEC1 milliVolts, "degF"
The integer division throws out the ones digit, and the DEC1 calls it out.
I really appreciate it!
