phase relationship between PLLA and Pixels
in Propeller 1
Was just thinking, suppose I setup the video generator and execute a waitvid to feed it a pixel and color data that makes it alternate every pixel. (1010101010...1010) Now suppose I have setup the PLL to output on a pin. If I put both on an oscilloscope how much phase difference will I see between them due to the differing propagation times of the various parts.
https://www.parallax.com/search?search_api_views_fulltext=AN00
and the DAT Sheet?:
https://www.parallax.com/downloads/p8x32a-propeller-datasheet
Is Kuroneko even around anymore?, as he would be the guy to ask.
The color burst is generated by PLLA, and the pixel clock is expressed as X number of pixels clocked out per PLLA.
Possible phase error is 1/(number of PLLA cycles per pixel). Something like that, anyway. Never measured it.
Edit: That is just the possible granularity of it, not a direct error percentage.
It remains constant when P1 is running, and will vary on a reset, and or driver restart.
On most drivers, this error is small. On something like VGA, it manifests as a very small shift in pixel position, which digital monitors correct for. A CRT will display it, but you have to have a good one to see it. Or you have to have a small number of pixels per PLLA. Ideally both.
For TV, Eric Ball generated a color burst manually, just using pixels to approximate the waveform, to insure a constant phase between pixels and the color burst reference, basically taking PLLA out of the equation. The P1 color phase generator isn't used at all.
That was necessary to generate true artifact color, as in say an odd pixel being red, an even one being blue kind of thing, like say an old Apple 2, or Atari computer would do.
The phase error can be seen in the parallax driver, by changing the number of scan lines to even, so the color burst is static, then put a swatch of red on the screen, and a blue one overlapping it.
A better TV will show a fringe color at the boundary. Reset the prop to see it change. That fringe color will be one of a number of shades possible, depending on the number PLLA cycles per pixel there are.
Later TV drivers minimized this by running a higher PLLA, say some multiple of the color burst.
This error, and jitter in general, also makes a PAL driver difficult to get good color purity on without a crystal.
