Weird issue with openspin preprocessor — Parallax Forums
maccamacca Posts: 1,026
edited 2017-11-04 19:52 in Propeller 1
Hi,
I'm facing a weird issue when using the preprocessor directives with openspin, I don't understand if it is a bug or I'm missing something, hope someone can help.
The following sample code:
CON
    _XINFREQ = 5_000_000
    _CLKMODE = XTAL1 + PLL16X
OBJ
    debug  : "com.serial.terminal"
PUB start | temp
   debug.start(115200)
#ifdef MODE1
    aaa
#else
    bbb
#endif
    waitcnt(CNT + CLKFREQ)
Fails to properly compile the preprocessor directive, no matter how I define it on the command line, it always fails on the bbb statement (should fail on the aaa statement)
openspin -b -u -DMODE1 preproc.spin
Propeller Spin/PASM Compiler 'OpenSpin' (c)2012-2016 Parallax Inc. DBA Parallax Semiconductor.
Version 1.00.80 Compiled on Nov  4 2017 20:31:52
Compiling...
preproc.spin
preproc.spin(18:5) : error : Expected an instruction or variable
Line:
    bbb
Offending Item: bbb
However if I remove the OBJ section, the compiler works as expected:
CON
PUB start | temp
   'debug.start(115200)
#ifdef MODE1
    aaa
#else
    bbb
#endif
Compiling...
preproc.spin
preproc.spin(12:5) : error : Expected an instruction or variable
Line:
    aaa
Offending Item: aaa
Hope I'm not missing something obvious.
Any hint ?
