Looking for a cheap SERIAL character OLED or 7-seg LED display ...
It needs to have a reliable multi-year source and be less than 35 mm x 35 mm. in total size. Internal screen buffering is a must. Number of characters is not a factor. Four (with decimal points) would be enough, although more are definitely welcome.
Interface can be async, SPI, or I2C.
Ideas?
Ideas?
Probably more reliable than aliexpress when it comes to longterm availability.
Or this USA based company:
https://www.crystalfontz.com/c/oled-displays/29
The OLED we carry has been a reliable, long-term supply. But like most of these parts, it's probably based on cell phone overstock from prior production runs. I'd be happy to connect you directly to the supplier.
Ironic isn't it? Oh and at one time they were a reseller for Parallax Prop items. I won't go into details concerning FTDI and here.
I think it's a truism that the more integrated a product is, the less one can rely upon its availability long-term. For long-term reliability, it's best to design in multi-sourced jelly-bean components and do the integration yourself. But what if you only need hundreds, rather than thousands? 'Seems like a lose-lose proposition, unless your customer can stand a significant mark-up for low-volume custom assembly.
Thanks, Ken! Although I'm not optimistic, I'll follow any lead at this point.
Small sizes, check.
Retains pixel display between updates, check. (at microamps current, if it matters)
Sharp has them in distribution, however, some earlier models have been dropped.
Cheap? Not. Future Electronics usually has the best domestic prices but they are showing zero stock.
