Anyone ever used Prop inputs to sense water ?
in Propeller 1
I am building a device to sense water. I'll have a common probe (ground) in the water then 2 different probes at 2 different heights above the water. Want to sense when the water is rising to the different levels. I was thinking maybe tieing the inputs high with a very large resistance to prevent them from floating either way then when the water rises to the probe it makes a circuit to ground.
How long do you need this to last, how often will you clean this, and how clean is the water ?
Simple passive probes need water less than 100% pure, but not too impure or the rise/lower of level leaves a conducting residue behind.
As little as possible to never.
It's wastewater. Think of floor drain or sewer backup.
Right now I'm using bared copper wire and yes I've noticed that it gets corroded and non conductive after a period of time (year?). Maybe stainless steel would be better? But my main question is whether the Prop inputs would sense the resistance of the water. I'll have to set up a prototype and see.
My present circuit uses CMOS logic and works OK. I want to add some additional "smarts" to my device is all.
I may just do that. Thanks.
