Activity Board power switch
DrPop
in Propeller 1
Just curious if anyone has replaced the power switch on an Activity board? Wondering how hard it is to remove and re-solder. Over time, I've purchased 7 Activitybots for a club/class at my daughter's school and two of them have the little plastic tab on the power switch broken now.
Thanks for any ideas or tips if anyone's done this.
Do you have replacement switches? DigiKey carries them.
https://www.digikey.com/products/en?keywords=ckn9543-nd
Try calling Parallax Tech Support for help with this.
Contact me at kgracey@parallax.com and we'll cross-ship a couple of PABs under an RMA number.
FWIW This is the way Parallax does business. That's why we love Parallax
Just contact Ken and get them replaced, easypeasy and why we love Parallax!
Jim
Not only have I built tons of pcbs, including SMT 0402 and 0.5mm pitch ICs, but I don't damage boards either.
If you are removing an old component, see if you can break it down without putting pressure on the pcb. Then you can remove a pin at a time. Helps to have some form of pcb vice so you can heat the solder on one side while pulling the pin on the other side with tiny pliers. Make sure there is plenty of solder on the pin so it heats quickly. Don't keep heat on the pcb any longer than absolutely necessary. Once the pins are out, solder and then suck the hole clean. Here is where the solder sucker on the opposite side helps, or solder braid on the same side as the iron.
Small pliers and cutters are your friend, as is solder flux when resoldering.
Hard to show in a forum post how impressed I am with this experience, but your customer care is real and has me looking forward to coming back for more bots and accessories in the future.
