P26 LED Stays on upon turn on
in Propeller 1
I have had my Activity Board for a couple of weeks. The LED for P26 stays on immediately upon turn on. There are no programs loaded and cleared RAM and EEPROM every time before shut down.
Any ideas? Defective board.
Jason
Jason
@DigitalBob - Excellent suggestion!! I'm embarrassed I didn't think of doing that. The LED does work normally...blinks in accordance with programming code. However, the LED turns back on and remains on until I put a coding in for P26 to output low.
Any other thoughts on why the LED remains on?
The ideas above are certainly appropriate.
@Electrodude - I loaded your code and ran it. The toggling of input to output pin worked fine.
During any loading (F10 or F11) the P26 LED is on. Not sure if that helps, but thought I would mention it.
Thank you all for your assistance with this.
Jason
Sincerely,
Jason
It's made right here, in Rocklin, California USA by American workers (and some veterans too) and includes our guarantee of workmanship! Even if you manage to blow it up I'll replace it for you.
Go forth and program. I mean, go Spin and program. Or Blockly, or ASM, or Tachyon, or whatever you want.
Copy that. The LED was never on when I first turned it on, so I thought something might be wrong with the board. LED sure is bright!
Thank you for taking the time to assist with this issue.
