Neato XV LIDAR
In the quest for cheap LIDAR I found there are quite a few <$100 units on ebay. They're used and designed for the Neato robotic vacuum cleaners.
Here is an example - http://www.ebay.com/itm/Neato-BotVac-Lidar-Distance-Sensor-Original-Factory-Part-65-70E-75-80-85-D/253168956088
It looks similar to the unit here - http://www.robotshop.com/en/rplidar-a1m8-360-degree-laser-scanner-development-kit.html
Also appears to be serial - https://xv11hacking.wikispaces.com/LIDAR+Sensor
I'm mostly looking to just play around, if it will fit on an AB maybe drive around. If everything goes well possibly put it on my rover. Does anyone have experience with this LIDAR unit?
Trying to resist.
Trying.
I have some medical grade electronic equipment sanitizer. It is pretty gross to think about where it came from. I'll post some pics when it gets here.
I'm not entirely sure what to do with it. First I'd like to see if I can use a pair of ESP8266s as a wireless bridge. Then I can put the LIDAR on an AB or Scribbler, do some processing on my PC, and send back commands via XBee.
