Which tutorials for the ASC+
First, is this the right forum? I assume the ASC+ uses a Propeller 2 but I'm not sure.
Second, I'm using an ASC+ and a BOE Shield. I don't find any tutorials specifically for this combination, so i tried the "Getting Started with the Propeller BOE" tutorial. Right off the bat, I run into differences between the Propeller BOE and the combination I'm using. I'm trying the "Blink a Light" but the tutorial refers to built in LED's on the Propeller BOE that I don't have. I can build the LED circuit myself, but I'm concerned about other differences later.
Is there a better set of tutorials that I should be using?
Thanks in advance.
Thanks in advance.
Are the numbers in your avatar referring to vacuum tube pins?
Yep. He's an oldie (like some of us here)
The ASC+ does have an SD card socket on the bottom. If you use it, you can't use I/O pins P8, P11-P13 for anything else.
Moved to Prop !
Is it possible to jury rig cables to pull the power off of the 3 wire sockets and reroute the control pin to another output.
