Parallax Propeller Plug - knocks out USB scanner
I have a strange situation going on with my set-up.... I have a Propeller Plug, and it works great.
I have a Windows 10-based laptop. I've attached a USB2 hub, and I have a USB scanner, UPS and wireless mouse dongle attached to the hub. I'm using the hub because the laptop itself is hard to reach from my workbench.
When I attach the plug onto the USB2 hub, it knocks out the scanner. The scanner basically keeps disconnecting/connecting every second infinity. I remove the plug, and the scanner re-mounts and all is good. I have two of these plugs, and both of them causes the same problem. I don't have a problem with the UPS or the wireless mouse - both are functional just fine.
Of course, the fix is to connect the plug to a different USB bus. But purely for philosophical and intellectual reasons, I'd like to understand what would cause the scanner to react like this with the plug connected?
Aloha!
Aloha!
If you right click a HUB in Device Manager and click the Power tab you can see the total power available (per port) and power required for attached devices.
This is from Windows 7:
first of all, welcome to the forums.
The USB-Standard allows the Host to vary the provided mA per port, and allows Devices to ask for some mA. So the voltage drop you see is insufficient supply.
That is the reason for powered USB-Hubs, because one can attach up to 127(?) devices on one USB-bus. Theoretically.
you left out the mA number after connecting the PropPlug. Could you just connect the PropPlug and measure the mA it uses?
just curious,
