how can i delete data from RFID tag?
I have a project regarding RFID Tag and I have used RFID read/write.
So i have the ability to write data into the RFID Tag. For some reason, i need to clear back what i have write into the RFID tag except the RFID Tag id.
I hope someone from parallax forum can hep me to solve this problem.
Thank You
Thank You
There's a link to a datasheet in the tag documentation. The datasheets claims the chip used can be rewritten at least 100,000.
This device should be able to write new information to the card. I haven't used these devices myself. I'd think you'd use the same technique you used to write zeros to the card to write new information.
Which Parallax products are you using. Some tags are read only, some are read/write.
Also the RFID reader makes a difference. Some can write, some can not.
