How many characters needed to display X numbers of longs decimal
I am trying to display a given buffer of longs (say 1 to 1000) as one decimal number over serial. So I have to output the leftmost decimal character first.
I already can do that in HEX, it is way more easy there.
So what I need, is a way to figure out how much decimal places are needed for the biggest needed divisor.
Take PST as example:
Or, to be precise, I need a way to calculate that biggest needed divisor itself, not just the number of digits, but that would be ok also.
for 1 long it is 10 digits - 1_000_000_000
for 2 longs it is 19 digits - 1_000_000_000_000_000_000
for x longs it is ?
how does this progress, and why?
Is there any trick to calculate the needed digits, instead of multiplying 1 by ten until my number runs out of longs and sets a carry flag?
curious,
PRI Dec(value) | i, x
x := value == NEGX 'Check for max negative
if value < 0
value := ||(value+x) 'If negative, make positive; adjust for max negative
ser.Tx("-") 'and output sign
[b] i := 1_000_000_000 'Initialize divisor[/b]
repeat 10 'Loop for 10 digits
if value => i
ser.Tx(value / i + "0" + x*(i == 1)) 'If non-zero digit, output digit; adjust for max negative
value //= i 'and digit from value
result~~ 'flag non-zero found
elseif result or i == 1
ser.Tx("0") 'If zero digit (or only digit) output it
i /= 10 'Update divisor
for x longs it is ?
curious,
btw, we can also print out 64-bit numbers too.
But I try to do that with my BigInts, so the memory needed to buffer a entire Number of characters is just not there.
That is why I mentioned I need to output the leftmost digit first.
I guess I try brute force first, and multiply my divisor by ten until I exceed the numbers of longs asked for or the divisor is bigger then the number to be outputted!.
that should work.
not sure what you are asking here, but isn't this just log2:log10 as in
log(2^32) = 9.632
log(2^64) = 19.265
etc
sadly by now I can not do a log(2^32000), what I would need for my current longest Int on a P1.
But I like the way you think.
but log2:log10 is a fixed 0.30102999566 Digits per binary-bit, if you know the Binary bits, you can derive the decimal digits, and then round-up to nearest whole number.
(+1 if you need sign)
