multicog variable sharing
Beavis3215
When programming the propeller in C, If you have processes in cog 0, 1, and 2, how do you share data generated in cog 1 with 0 and 2?
In this example, cog 0 can't see Imax generated in cog 1.
Cog 2 needs to see imv generated in cog 1.
What is a good approach?
GFI for safety extension cord
#include "simpletools.h"
#include "adcDCpropab.h"
void measure_imax();
void throw_breaker();
volatile int imv;
volatile int imax;
int main() // Main function runs 7 segment LED's in cog 0
cog_run(measure_imax,128); // Start littlebird measurments
cog_run(throw_breaker,128);
adc_init(21, 20, 19, 18);
set_directions(15, 1, 0b111111111111111); // pins 15 through 0 are outputs
int d[] = {0b1110111, 0b1000100, 0b1101011, 0b1101110, 0b1011100, //digits 0 through 9
0b0111110, 0b0011111, 0b1100100, 0b1111111, 0b1111100};
pause(1000); // Let hardware boot up
while(1)
float amps = (imax - 2700) *.003; // Scale Littlebird voltage to mean amps
int a = (int) amps; // intger part of amps
float b = (10 * (amps - a));
int c = (int)b; // fractinal part of amps
print("%f, %d, %d\n", imax, a, c);
set_outputs(15, 9, d[c]); // c is the decimal value
set_output(1,1); // pin 1 is the decimal digit driver
pause(8);
set_output(1,0);
set_outputs(15, 9, d[a]); // a is the integer value
set_output(2,1); // pin 2 is the integer digit driver
pause(8);
set_output(2,0);
void measure_imax()
while(1)
for (int sample = 0; sample <= 60; sample++) // Littlebird samples per loop
float i = adc_volts(2);
int imv = (int)(i * 1000); //
if (imv < 2700) //
float temp = 2700 - imv; //
imv = temp + 2700; //
float j = adc_volts(2);
int jmv = (int)(j * 1000);
// Invert samples below 2.7 volts
if (jmv < 2700) // to the same value above 2.7 volts
int temp = 2700 - jmv; //
jmv = temp + 2700; //
if (jmv > imv)
imv = jmv;
imax = imv; // Stores maximum voltage sample
set_direction(0,1);
set_output(0,1);
while(1)
if (imv > 2900)
set_output(0,0);
cog_end;
Whether this is a "good" approach I can't say but it does work for me.
This is strictly a user controlled method, and does not rely on any C library or function other than global scope.
EDIT: The function measure_imax declares a local variable named imv. This causes it to use the local variable imv instead of the global variable imv. However, imax should be updated.
EDIT2: The statement "imax = imv" references the global variable imv that never gets updated. Eliminate the declaration of the local variable imv.
EDIT3: You should also fix the format used in your print. You are using %f for imax, which is an int. You should use %d.
/* GFI for safety extension cord */ #include "simpletools.h" #include "adcDCpropab.h" void throw_breaker(); void display_led(); static int imv; static int imax; int main() { cog_run(throw_breaker,128); // Start littlebird measurments cog_run(display_led,128); adc_init(21, 20, 19, 18); while(1) { for (int sample = 0; sample <= 50; sample++) // Littlebird samples per loop { float i = adc_volts(2); imv = (int)(i * 1000); // // if (imv < 2700) // { // float temp = 2700 - imv; // imv = temp + 2700; // } // float j = adc_volts(2); int jmv = (int)(j * 1000); // Invert samples below 2.7 volts if (jmv < 2700) // to the same value above 2.7 volts { // int temp = 2700 - jmv; // jmv = temp + 2700; // } // if (jmv > imv) { imv = jmv; } } imax = imv; // Stores maximum voltage sample //print("imax = %d\n",imax); } } void throw_breaker() { set_direction(0,1); set_output(0,1); while(1) { if (imax > 2900) { set_output(0,0); cog_end; } } } void display_led() { set_directions(15, 1, 0b111111111111111); // pins 15 through 1 are outputs int d[] = {0b1110111, 0b1000100, 0b1101011, 0b1101110, 0b1011100, //digits 0 through 9 0b0111110, 0b0011111, 0b1100100, 0b1111111, 0b1111100}; while(1) { float amps = (imax - 2700) *.003; // Scale Littlebird voltage to mean amps int a = (int) amps; // intger part of amps float b = (10 * (amps - a)); int c = (int)b; // fractinal part of amps set_outputs(15, 9, d[c]); // c is the decimal value set_output(1,1); // pin 1 is the decimal digit driver pause(8); set_output(1,0); set_outputs(15, 9, d[a]); // a is the integer value set_output(2,1); // pin 2 is the integer digit driver pause(8); set_output(2,0); } }
