Variable names in tutorials
Seairth
I just read through the pong tutorial, which is also the first Blockly tutorial that I've read. One thing that caught my attention was the use of short, non-descriptive variable names. As a software engineer, I find that to be a generally poor practice, especially when teaching others to program. The variable should be descriptive enough to understand it's usage without having to consult any other code. All programmers (myself included, occasionally) eventually get lazy and start shortening our variable names, but that should not be how you start your programming career. Teach good programming practices, then let them go off and learn bad practices on their own.
http://learn.parallax.com/tutorials/language/blocklyprop/capacitive-touch-pong-game
SVG would be somewhat better: https://webmasters.stackexchange.com/questions/13848/do-search-engines-index-text-contained-in-svg-elements
Can you be a bit more specific about which variable names you're referring to? Want snake case, camel case or something else? Please provide a few more specifics for us.
This particular tutorial was prepared by Carson, a 17-year-old intern who's headed to college in a few weeks.
@SRLM: will look at that next.
Thanks!
Ken
An SVG linked via an img tag is not searched: https://www.w3.org/TR/SVG2/text.html Although if you open the SVG in it's own tab, it's searchable.
However, if you embed the SVG directly in the host document, it is searchable (save page, replace img tag to experiment with this)
Related, if you generate the content dynamically it is also find in page-able, eg https://bl.ocks.org/mbostock/2565344
x might normally be ok in a graphics/math context, but since there is also a paddleX, it's a bit confusing.
Good variable names are important, especially since they're the main documentation in this code (does Blocky have comments?)
Minor note: the yellow arrow in this image http://learn.parallax.com/tutorials/language/blocklyprop/capacitive-touch-pong-game/calibration-and-programming seems to hang out a bit, without context. I would either add a matching note to the image, or in the caption add a note with something like "in the yellow text ..." and have the word yellow colored to match.
Yes, those were the ones that stuck out for me too (also, "s").
