Notepad++ UDL (User Defined Language) or xml Style definition file for .spin
in Propeller 1
I started using Notepad++ for ALL other programing. I quickly got so used to the way Notepad++ highlights selections that now program spin using the PropellerIDE is hard to do.
Is anyone using Notepad++ for their programming? And if so, do you have a UDL style definition xml file handy, that you can share?
Also, Notepad++ is so powerful, it would be great if a plugin could be developed to flash the spin files to the memory chip from within Notepad++!
Any thoughts are, as always, most welcome.
Edit: Never mind, I just looked at Notepad++ and you need XML.
Is it really better than say Microsoft's Visual Studio Code https://code.visualstudio.com/ Which is also Free and Open Source but runs everywhere?
It would be very easy to make a Propeller loader plug-in for VS Code.
Thank you for the upload - this gave me a good start. Here is my xml file
YES
.xml is not accepted.
Could you double check that the uploaded file matches what you're using? I think there might be some html escape sequences in the file that shouldn't be there.
Joe
Note: you need a recent version of Notepad++ that has UDL 2.1 support.
