TSL1401-DB
in BASIC Stamp
Hello!
I have a TSL1401-DB mounted to BS2pe_MOBO board. I'm using the monitor program to see the output of the sensor. Basic operation is working. I attempted to make use of the Triggered acquisition without success.
I'm driving the ST pin on the 6 pin header of the daughter board. A high here causes a low on jumper J2 (jumper is installed). J2 connects to the MoBo board through the 12 pin header to P3 of the BS2pe processor. According to the documentation a high to low transition should initiate an acquisition. I don’t see evidence of the acquisition as the scope window on the monitor program doesn’t update. Interesting to note is that I can get Gated acquisitions to work: scope window updates continue while P3 is low.
Any ideas?
Thx,
Rob
Any ideas?
Thx,
Rob
I'm the designer of the BS2pe_MOBO and the TSL1401-DB, and I'm the author of the monitor software. 'Sorry you're having trouble with the triggered mode. In ten years, you're probably the first person to try it! So ... I'll have to take a look at the AVR firmware to see what's going on.
BTW, do you have another daughterboard plugged into the other socket? The reason I ask is that P2 and P3 are shared between both sockets.
No, socket A is unused. The daughter board uses socket B.
Rob
By the way, is there any way to get the raw sensor data out to a file? Do you use the ATTiny's ADC to convert the sensor's output?
Thx,
Rob
Here's a program that will dump pixel values to the debug screen in CSV form. From there you can copy and paste into a file, if you like:
' ========================================================================= ' ' File...... tsl1401_dump_gray.bpe ' Purpose... Dump pixel values from the TSL1401-DB using the MoBoStamp-pe. ' Author.... Phil Pilgrim ' E-mail.... propeller@phipi.com ' Started... 22 Dec 2010 ' Updated... ' ' {$STAMP BS2pe} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' This program dumps analog pixel values from the TSL1401-DB via the ' TSL1401.hex firmware for the MoBo's AVR coprocessor. ' -----[ I/O Definitions ]------------------------------------------------- owio PIN 6 'Pin for OWIN and OWOUT to AVR coprocessor. ' -----[ Constants ]------------------------------------------------------- ' Commands SETLED CON $EB 'Set LED strobe and brightness/time from next byte. 'Flag to OR to brightness/time (0 - 127) value. TIME CON $80 'Set strobe: value (0 - 127) is 0 - 3.4mS at 100% on. INTEN CON $00 'Set intensity: value (0 - 127) is 0 - 49.6% on. SETBIN CON $EC 'Set threshold, hysteresis, and filter (3 bytes). 'Filter flags. FLOAT CON $80 'Threshold is floating per filter value (0 - 7). FIXED CON $00 'Threshold is fixed. WINDOW CON $40 'Threshold is a window (outside of hysteresis band). LEVEL CON $00 'Threshold is a level with hysteresis. SETEXP CON $EE 'Set exposure to byte (1 - 255) following: 0.27 - 68mS. ACQGRAY CON $A0 'Acquire and dump a grayscale image. ACQBIN CON $A4 'Acquire a binary image. ACQAND CON $A1 'Acquire binary image ANDed w/ previous. ACQOR CON $A2 'Acquire binary image ORed w/ previous. ACQXOR CON $A3 'Acquire binary image XORed w/ previous. ACQANDNOT CON $A5 'Acquire binary image ANDed w/ NOT prev. ACQORNOT CON $A6 'Acquire binary image ORed w/ NOT prev. ACQXORNOT CON $A7 'Acquire binary image XORed w/ NOT prev. ACQDIFF CON $A3 'Idiom for ACQXOR. ACQSAME CON $A7 'Idiom for ACQXORNOT. XTRIG CON $08 'External trigger flag, ORed to ACQ commands. CNTNEW CON $C8 'Count pixels/edges between new bounds. CNTNXT CON $C0 'Count pixels/edges between current bounds. FNDNEW CON $F8 'Find first pixel/edge between new bounds. FNDNXT CON $F0 'Find first pixel/edge between current bounds. 'Modifiers, ORed to CNTNEW, CNTNXT, FNDNEW, and FNDNXT. NXT CON $00 'Continue from where last CNT or FND left off. BKWD CON $04 'Search backward. FWD CON $00 'Search forward. DRKPIX CON $00 'Target is a dark pixel. BRTPIX CON $02 'Target is a bright pixel. DRKEDG CON $03 'Target is a bright-to-dark edge. BRTEDG CON $01 'Target is a dark-to-bright edge. DUMPADR CON $DA 'Dump data, beginning at addr, and until reset. 'Address constants for single byte arg following DUMPADR. PIXELS CON $00 'Beginning of binary pixel buffer (32 bytes). RESULTS CON $20 'Beginning of results buffer. MINPIX CON $20 'Value of darkest pixel (0 - 255). MINLOC CON $21 'Location of darkest pixel (0 - 127). MAXPIX CON $22 'Value of brightest pixel (0 - 255). MAXLOC CON $23 'Location of brightest pixel (0 - 127). AVGPIX CON $24 'Average pixel value (0 - 255). DUMPID CON $DD 'Dump the firmware ID (returns 3 bytes). DUMPFLAGS CON $DF 'Dump error flags (returns 1 byte). 'Bit positions in returned byte. BADCMD CON $80 'Unrecognized command. CANTBUF CON $40 'Attempt to buffer unbufferable command. CMDOVF CON $20 'Command buffer overflow. DATOVF CON $10 'Result data buffer overflow. ' -----[ Variables ]------------------------------------------------------- flags VAR Byte busy VAR Bit ' -----[ Initialization ]-------------------------------------------------- PAUSE 10 'Wait for AVR to finish reset. ' -----[ Program Code ]---------------------------------------------------- EXPTIME CON 60 i VAR Byte j VAR Byte char VAR Byte(16) DO OWOUT owio, 1, [SETEXP, EXPTIME, ACQGRAY] GOSUB Ready FOR i = 0 TO 7 OWIN owio, 8, [STR char\16] FOR j = 0 TO 15 PUT i << 4 + j, char(j) NEXT NEXT FOR i = 0 TO 127 GET i, char IF (i = 127) THEN DEBUG DEC char(15), 13, 13 ELSE DEBUG DEC char, "," ENDIF NEXT LOOP END ' -----[ Subroutines ]----------------------------------------------------- ' -----[ Ready ]----------------------------------------------------------- ' Wait for the driver to become not busy. Ready: DO OWIN owio, 4, [busy] 'Read busy bit. LOOP WHILE busy 'Keep checking until it goes low. RETURN ' -----[ GetError ]-------------------------------------------------------- ' Read the error flags from the driver. GetError: OWOUT owio, 0, [DUMPFLAGS] 'Read the error flags. OWIN owio, 0, [flags] IF (flags = $FF) THEN 'If $FF, driver is waiting for a reset. OWOUT owio, 1, [DUMPFLAGS] 'So reset and try again. OWIN owio, 0, [flags] ENDIF RETURN-Phil
From the documentation: seems to say triggering and gating use the same pin
Trigger/Sync Control: Scans can be free-running, triggered, or gated. Triggering and gating
are controlled by Pin 3, which is a BS2pe port common to both daughterboards. When triggering
is set, a high-to-low edge on Pin 3 will cause a single scan to be acquired. When gating is set,
scans will be obtained continuously while Pin 3 is low
In another place the documentation states:indicating P3 of the STAMP processor is used for triggering
Although the acquire commands do not take an argument, there is one optional modifier that can be
ORed to it. This is the external trigger constant, XTRIG, which has a value of $08. When XTRIG is
ORed to any acquire command, the command, when executed, will wait for a falling edge on BASIC
Stamp pin P3, then begin its exposure. Since P3 is common to both daughterboard sockets, this same
pin triggers the TSL1401-DB in either one. This enables exposures to be synchronized precisely with an
external event, such as an encoder pulse or optosensor output.
Based on the daughter board schematic that appears to connect to the sensors clock net. I'm confused.
I've attached the schematics I'm using.
Rob
1. Use P3 (or any other non-committed pin) and let the BASIC Stamp program wait for the edge there before issuing an Acquire command.
2. Issue an Acquire command to the AVR firmware with the trigger modifier to wait for an edge on P2.
In case #2, the AVR firmware accepts the command, tristates the TSL1401 CLK line, waits for an edge via the TSL1401-DB's Schmitt-trigger inverter, then reasserts CLK and proceeds to acquire a scan.
Obviously, #2 obtains the scan in closer proximity to the edge than does #1. For this reason, it's the method used by the monitor program except when Sync is enabled. In the case of Sync, it waits for an edge on P3 (the trigger, in this case), then it waits for a pulse on P0, which is connected to the 6-pin block on the TSL1401-DB. If it times out waiting for the pulse, it just goes ahead and issues the Acquire command anyway. The disadvantage of doing it this way without a synchronizer attached, is that there will be a delay of 123.6 ms after the trigger before the Acquire is issued.
The synchronizer was meant to be a small board with an optical sensor used to detect 50 or 60 Hz flicker and send pulses in synchrony with that flicker. I made one prototype, and it worked, but it never went into production due to lack of demand.
Any discrepancies in the docs from my description above are my fault, and I apologize for whatever confusion they might have caused.
_____________
Regarding the data capture: unfortunately, the monitor program has no way at present to save captured data to a file. This would definitely be a nice feature and is something I'm considering for a future version.
You can use the code snippet I posted to do what you want, as I indicated. But you will have to include code for setting the exposure time and either wait for the trigger edge in that program or set the Trig bit in the Acquire command to wait for an edge on P2. My snippet and the monitor program cannot both be used at the same time.
Welcome to the Parallax forum!
You might think that an illuminated shiny surface will always show up as "white", but that is not necessarily the case. What the camera sees is whatever the shiny surface is reflecting. The best way to examine such a surface for dark-colored marks, scratches, etc., is to position a matte-white card so that the camera sees it reflected in the shiny subject. Then illuminate the card, not the subject.
