Block move SETQ/Cordic related issue
in Propeller 2
Hi Chip
I've found an issue with the Cordic giving incorrect results when preceeded by a block move instruction pair.
I have to insert a spacer instruction between to get correct results.
The spacer instution can be any instruction.
It almost like a SETQ value of $FFFFFFFF is being passed into the cordic.
I went back to V18 FPGA image and the issue was there too.
Here's some example code for the P123 board to demonstrate the issue.
dat org
loc pa,#\parms
loc ptrb,#@mycode
setq pa
coginit #16,ptrb
cogstop #0
dat orgh $400
parms long 60_000_000 'parameter block
long 115200
long 63
long 62
org
mycode bmask dirb,#15 'enable leds
setq #3
rdlong parm1,ptra 'block move 4 longs
nop '???? Needed for correct Cordic result ????
qdiv parm1,parm2
getqx outb 'show result on leds
jmp #$
parm1 long 0
parm2 long 0
parm3 long 0
parm4 long 0
At the end of a cog-register block read or block write (SETQ+RDxxxx/WRxxxx), an extra clock cycle is spent to re-read the next instruction's S and D registers, since the block move had corrupted the RAM's data latches. This reading was being done for D, but not for S, due to some absent-mindedness on my part. I asserted the extra read signal on the other RAM port and a 9-bit address mux for the S register, and now the problem is fixed.
Here is a new 2-cog FPGA image for the Prop123-A9 board...
https://drive.google.com/a/parallax.com/file/d/0B9NbgkdrupkHUWNUSDc2XzkyTFE/view?usp=sharing
I'll take it for a spin when i'm back at my FPGA board tonight.
http://forums.parallax.com/discussion/167026/drvh-instruction-causes-dirx-issues
and
http://forums.parallax.com/discussion/167052/streamer-nco-rollover-event-misfire
Thanks for pointing this out. I knew there was at least one other thing that I have to chase next. But, now I remember there were, indeed, two things. I'll get to these in the morning. You just saved me a bunch of time by pointing these out. Thanks, again.
Google drive permissions need to be changed for allow access to this file.
Sorry about that. I clicked the wrong permission button. It should work now:
https://drive.google.com/file/d/0B9NbgkdrupkHUWNUSDc2XzkyTFE/view?usp=sharing
Thanks Chip
Thanks for your help in finding and testing bugs!
