Is it possible to automatically detect 6Mhz crystal as well as 5/10?
Peter Jakacki
Many years ago our famous Phil Pilgrim wrote a very tricky and useful routine to detect whether a Prop was running a 5Mhz or 10Mhz crystal. Well, it couldn't really tell if it were 5Mhz exactly but it could tell the whether it was in that range. rather than double.
Now perhaps this question is more for Phil but I throw it open for anyone to be able to comment but is it possible to detect 5/6/10 Mhz crystals automatically? I think the difference between 5 and 6 and the variations in silicon would preclude being able to detect this just as it would be almost impossible to detect 6.5Mhz too so I will say that this is IMPOSSIBLE!
Any takers?
I may however use baud-rate detection from ANSI terminal responses to reset and lock in the exact crystal frequency as a workaround and make sure all code references this for timing.
Phil's code that I use in Tachyon:
Any takers?
CLKSET
?(c) Copyright 2009 Philip C. Pilgrim (propeller@phipi.com)
see end of file for terms of use.
This object determines whether a 5MHz or 10MHz crystal is
being used and sets the PLL accordingly for 80MHz operation.
The main program should use the following settings:
_clkmode = xtal1 + pll8x
_xinfreq = 10_000_000
org _RUNMOD
_setpll movi ctra,#%0_00001_011 'Set ctra for pll on no pin at x1.
movi frqa,#%0100_0000_0 'Set frqa for clk / 4 (= 20MHz w/ 10MHz crystal, i.e. too high).
add pllx,cnt 'Give PLL time to lock (if it can) and stabilize.
waitcnt pllx,#0
movi vcfg,#$40 'Configure video for discrete pins, but no pins enabled.
mov vscl,#$10 'Set for 16 clocks per frame.
waitvid 0,0 'Wait once to clear time.
neg pllx,cnt 'Read -cnt.
waitvid 0,0 'Wait 16 pll clocks = 64 processor clks.
add pllx,cnt 'Compute elapsed time.
cmp pllx,#$40 wz 'Is it really 64 clocks?
if_z mov pllx,#$6f ' Yes: Crystal is 5MHz. Set clock mode to XTAL1 and PLL16X.
if_z clkset pllx
if_z wrbyte $-2, #4 'update clkmode location
jmp unext
pllx long $1_0000 '65536 clks for pll to stabilize.
This would have to be without external components so that just like Phil's original code it could simply just work on any Prop system.
I have thought about using characteristics of the EEPROM perhaps but that is not precise enough but I suppose a small cap on the SCL line in conjunction with the pullup might provide some kind of information assuming that normal I2C activity uses push-pull SCL so that a small cap shouldn't be a problem. Or maybe a series resistor with the cap is worthwhile exploring so that it doesn't interfere with passive clocking.
However this would always require a hardware mod in which case it is just as easy to specify a clock frequency.
I am out ATM so cannot search for the thread. You gave me Phil's code for the pllx88 versions.
