Loop not repeating correct number of times, help? — Parallax Forums
Hello everyone,
I'm trying to fire a light five times. I thought this loop would do that but it only fires twice. Does anyone have any ideas why?
                                                org          0
start                                         or        dira, light
                                                andn     outa, light
                                                mov     Count,#5
loop                                         or       outa, Pin                         'toggle light  on
                                                andn     outa, Pin                     ' toggle light off
                                                djnz     Count, #loop
  • What are the values of Pin and light, and where are they defined? Can you post your entire program, please?
    Also, your loop will complete in microseconds. Are you using a scope to count the pulses?
    Finally, there's nothing at the end to keep any random code that was loaded with yours from executing. You should either include an instruction that jumps to itself, or a cogstop to kill the cog.
  • Light goes on for 50 billionths of a second and then light goes off. Seriously?
    Where's your delay?
    Where's "Count"?
    Where's the rest of the code?
    Why would you code this in PASM anyway?
    edited 2017-07-13 22:29
    To learn PASM, perhaps? 'Probably did something very similar with my first PASM program. :)
  • JonnyMacJonnyMac Posts: 9,505
    edited 2017-07-14 03:20
    You're not revealing all of your code so there's no way to tell if you have problems beyond -- as Peter points out -- the output is being toggled so fast you'd need to have a 'scope on it to see the changes. Here's one that works with an LED. I ran it on a PAB. The LED and CYCLES constants are defined in the top part of the program, before the cognew(@entry, 0) call.
    dat
                            org     0
    entry                   mov     pmask, #1                       ' create pin mask
                            shl     pmask, #LED
                            mov     dira, pmask                     ' set pin to output mode
                            rdlong  delaytix, #0                    ' read system freq (tix/second)
                            shr     delaytix, #1                    ' divide by 2 (1/2s delay)
                            mov     count, #CYCLES                  ' set number of flashes
                            mov     timeout, cnt                    ' start timer
                            add     timeout, delaytix
    loop                    or      outa, pmask                     ' led on
                            waitcnt timeout, delaytix
                            andn    outa, pmask                     ' led off
                            djnz    count, #loop                    ' count down
                            cogid   cid                             ' shut down this cog
                            cogstop cid
    ' cog vars
    pmask                   res     1
    delaytix                res     1
    count                   res     1
    timeout                 res     1
    cid                     res     1
  • dayoade, Here's a link to some basic example code that you should find helpful.
  • dayoadedayoade Posts: 13
    edited 2017-07-14 00:47
    Thank you for your responses. I am using a oscilloscope and even when I added 0.5 sec delays I got fewer pulses then expected.
                                                    org          0
    start                                         or         dira, light             ' configure pin to output
                                                    andn     outa, light            ' set pin to input
                                                    mov      Counter, #5           ' counter for LED pulses
    loop                                         or         outa, Pin                ' toggle pin on
                                                    andn     outa, Pin               ' toggle pin off
                                                    djnz     Counter, #loop1      wz
                                        if_z      cogstop ID
    light       long  %000000_0110000_00000000_00000000
    Counter long 0
    ID           long 0
    Pin        long |<21
  • jmgjmg Posts: 15,194
    edited 2017-07-14 00:11
    dayoade wrote: »
    ... I am using a oscilloscope and even when I added 0.5 sec delays I got fewer pulses then expected.
                djnz     BlinkCounter, #loop1      wz
    Counter long 0
    BlinkCounter seems not declared, or loaded anywhere, whilst Counter is loaded but not used ?
    If you have a Scope, and an almost-working system, you likely just need some fault analysis...
    Change the #5 and see if the pulses change ?
    Are the pulses you do get, of expected width & spacing ?
    If you add another pin that sets just before the loop, and clears after DJNZ, what time does that take ?
  • [/quote]
    [/quote]
    Sorry it was supposed to be counter, if i change the amount of pulses, the firings are still coming up short of the number I want.
    dayoade wrote: »
    ... if i change the amount of pulses, the firings are still coming up short of the number I want.
    Ok that's a start, but short of you likely just need some fault analysis...
    Tabulate the Count, and what you see. Is it always -3 ?
    Did you add a start-end pin ?
    If you trigger on that, what do you now see ?
  • And presumably the djnz Counter,#loop1 jumps to loop? And you've got a cogID ID in there so the cogstop knows what to stop? People around here are generally quite willing to help, but it does require you post the entire, actual code.
    How sure are you that the assembly routine is even being loaded into a cog?
  • Elements in your code don't match the comments.
  • This is where I would cheat by coding in PropBasic and learn from the generated PASM :-)
  • Sorry for not posting the whole code. I thought it would just complicate the question. I appreciate the help.
                                                    andn    outa, light                ' set pins to input
                                                    mov     Counter,#5           ' Counter for LED pulses
    loop                                         or         outa, Pin              ' turn on LED 1
                                                    mov      Time, cnt
                                                    add       Time, Delay
                                                    waitcnt  Time, Delay              ' wait for 0.5 seconds
                                                    andn      outa, Pin             ' turn off LED 1
                                                   djnz     Counter, #loop    ' jump back to loop and decrease counter
                                                   cogid   ID
                                                   cogstop ID
    light           long  %00000000_01100000_00000000_00000000
    Counter      long      0
    ID               long      0
    Pin              long    |< 21
    Delay        long  40_000_000
    Time         res 1
  • jmg wrote: »
    dayoade wrote: »
    I'm getting two pulses instead of five. Is that what you mean by -3? And what do you mean by start-end pin?
  • dayoade wrote: »
                                                    mov      Time, cnt
                                                    add       Time, Delay
                                                   cogid   ID
                                                   cogstop ID
    Counter      long      0
    ID               long      0
    Pin              long    |< 21
    Time         res 1
    I think you need to put another delay after you turn off the LED. Otherwise, it just loops around and turns it back on immediately so you won't see the blink.
    edited 2017-07-14 16:58
    You have a half-second delay now between on and off, but none between off and back on again. So you're still not going to "see" any pulses without a scope.
    Also, please post the entire program, including the Spin code that starts the PASM cog.
    dayoade wrote: »
    Do you always get 2, no matter if you preset 5,7,13 etc ?
    If you are fixed on 2, then that tells you what you change and think is the counter, is not the real counter.
    dayoade wrote: »
    See above, this is a pin you set at the code before the loop, and clear after the loop completes.
    This should pulse once, and give a scope trigger to see all the other pulses.
    David Betz wrote: »
    yes, or, you could toggle the pin, and use just one delay. The scope toggles should match the loop counter.
    It is possible the scope has a trigger offset issue, so another separate way to check counting would help.
    CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    VAR
    byte datin[3], dp
    byte light1status, light2status, light3status, light4status
    word dtemp1, dout1, dtemp2, dout2, dtemp3, dout3, dtemp4, dout4
    long Command
    long pulsecount
    long cog
    PUB main
    ' UM245R communication Lines
      dira[7..0] := %00000000   ' input byte form UM245R
      dira[8] := 0               'input, RXF
      dira[9] := 1                 ' output, RD#
      dira[10] := 0              'input, TXE
      dira[11] := 1              ' output, WR#
      'Digital output communication lines, SN74HC595
      dira[12] := 1               ' output, clock
      dira[13] := 1               ' output, data line 1
      dira[14] := 1                ' output, latch 1
      dira[15] := 1                 ' output, data line 2
      dira[16] := 1                ' output, latch 2
      dira[17] := 1                'output, data line 3
      dira[18] := 1                'output, latch 3
      dira[19] := 1                 ' output, data line 4
      dira[20] := 1                 ' output, latch 4
      dira[21] := 1                    ' output, analog MUX 1
      dira[22] := 1                    ' output, analog MUX 2
      dira[23] := 1                    ' output, analog MUX 3
      dira[24] := 1                    ' output, analog MUX 4
      dira[25] := 0                    ' input, camera frame exposure signal
      outa[9] := 1
      outa[11] := 0
      outa[12] := 0
      outa[13] := 0
      outa[14] := 0
      outa[15] := 0
      outa[16] := 0
      outa[17] := 0
      outa[18] := 0
      outa[19] := 0
      outa[20] := 0
      outa[21] := 0
      outa[22] := 0
      outa[23] := 0
      outa[24] := 0
      light1status := 0
      light2status := 0
      light3status := 0
      light4status := 0
       ' set 4 LED drive voltage outputs to 0
      repeat 16
        outa[12] := 1           ' clock it in
        outa[12] := 0
      outa[14] := 1              ' latch it in
      outa[14] := 0
      outa[16] := 1              ' latch it in
      outa[16] := 0
      outa[18] := 1               ' latch it in
      outa[18] := 0
      outa[20] := 1                ' latch it in
      outa[20] := 0
     cog:= cognew(@RR, 0) + 1
    repeat
      repeat dp from 0 to 2
        repeat until ina[8]==0
        outa[9] := 0
        datin[dp] := ina[7..0]
        outa[9] := 1
        'change lightlevel1
      if datin[0]==2
        dout1 := datin[1] + datin[2]*256
        dtemp1 := dout1
        repeat 12
          if (dtemp1 & %0000100000000000)==%0000100000000000
            outa[13] := 1
          else
            outa[13] := 0
          outa[12] := 0
          dtemp1 <<= 1    ' shift left 1
        outa[14]:=1      'latch it in
        outa[14]:=0
        ' turn on light1
      elseif datin[0]==3
        if light1status==0
          outa[21] := 1
          light1status := 1
        elseif light1status==1
          outa[21] := 0
          light1status := 0
          'change lightlevel2
      elseif datin[0]==4
        dout2 := datin[1] + datin[2]*256
        dtemp2 := dout2
        repeat 12
          if (dtemp2 & %0000100000000000)==%0000100000000000
            outa[15] := 1
          else
            outa[15] := 0
          outa[12] := 0
          dtemp2 <<= 1    ' shift left 1
        outa[16]:=1     ' latch it in
        outa[16]:=0
        ' turn on light2
      elseif datin[0]==5
        if light2status==0
          outa[22] := 1
          light2status := 1
        elseif light2status==1
          outa[22] := 0
          light2status := 0
         ' change lightlevel3
      elseif datin[0]==6
        dout3 := datin[1] + datin[2]*256
        dtemp3 := dout3
        repeat 12
          if (dtemp3 & %0000100000000000)==%0000100000000000
            outa[17] := 1
          else
            outa[17] := 0
          outa[12] := 0
          dtemp3 <<= 1          ' shift left 1
        outa[18]:=1              ' latch it in
        outa[18]:=0
        ' turn on light3
      elseif datin[0]==7
        if light3status==0
          outa[23] := 1
          light3status := 1
        elseif light3status==1
          outa[23] := 0
          light3status := 0
          ' change lightlevel4
      elseif datin[0]==8
        dout4 := datin[1] + datin[2]*256
        dtemp4 := dout4
        repeat 12
          if (dtemp4 & %0000100000000000)==%0000100000000000
            outa[19] := 1
          else
            outa[19] := 0
          outa[12] := 0
          dtemp4 <<= 1  ' shift left 1
        outa[20]:=1   ' latch it in
        outa[20]:=0
        ' turn on light4
     ' elseif datin[0]==9
        'if light4status==0
          'outa[24] := 1
          'light4status := 1
        'elseif light4status==1
          'outa[24] := 0
          'light4status := 0
          ' Run Light Pulsing (Round-Robbin) with Processor 2
      elseif datin[0]==10
        pulsecount := datin[1] + datin[2]*256
        Command:=1
        repeat until Command==0
      elseif datin[0]==255
        reboot
    DAT
                                                    org          0
    RR                                              or       dira, LEDS                ' configure Pins as outputs (1)
                                                    andn     outa, LEDS                ' set Pins to input state (0)
                                                    mov      BlinkCounter,#10          ' Set Blink counter
    loop1                                       or       outa, Pin25               ' turn on camera
                                                    or       outa, Pin21               ' turn on LED 1
                                                    mov      Time, cnt
                                                    add      Time, OnTime
                                                    waitcnt  Time, OnTime              ' wait for ___ seconds
                                                    andn     outa, Pin25               ' turn off camera
                                                    andn     outa, Pin21               ' turn off LED 1
                                                    mov      Time, cnt
                                                    add      Time, Delay
                                                    waitcnt  Time, Delay
    loop2                                           or       outa, Pin25               ' turn on camera
                                                    or       outa, Pin22               ' turn on LED 2
                                                    mov      Time, cnt
                                                    add      Time, OnTime
                                                    andn     outa, Pin22               ' turn off LED 2
                                                    mov      Time, cnt
                                                    add      Time, Delay
                                                    waitcnt  Time, Delay
    loop3                                           or       outa, Pin25               ' turn on camera
                                                    or       outa, Pin23               ' turn on LED 3
                                                    mov      Time, cnt
                                                    add      Time, OnTime
                                                    andn     outa, Pin23               ' turn off LED 3
                                                    mov      Time, cnt
                                                    add      Time, Delay
                                                    waitcnt  Time, Delay
    loop4                                           or       outa, Pin25               ' turn on camera
                                                    or       outa, Pin24               ' turn on LED 4
                                                    mov      Time, cnt
                                                    add      Time, OnTime
                                                    andn     outa, Pin24
                                                    mov      Time, cnt
                                                    add      Time, Delay
                                                    waitcnt  Time, Delay
                                                    cogid ID
                                  if_z              cogstop ID
    LEDS         long  %00000011_11100000_00000000_00000000
    BlinkCounter  long  0
    ID           long 0
    Pin21        long |< 21
    Pin22        long |< 22
    Pin23        long |< 23
    Pin24        long |< 24
    Pin25        long |< 25
    OnTime      long  40_000_000
    Delay       long  20_000_000
    Time        res   1        'System Counter Workspace
  • Ya gotta remember that all cogs have access to the I/O pins. If the last posted code was current, it looks like you have cogs overlapping each other in the pin functions. And unlike TTL logic, highs rule in these outputs; each cog access to an I/O pin is an OR logic function so if any one cog says output, it's output. And if any cog on that pin has said it's an output and asserts a high, that cog rules and the pin will be output high.
    Go back through starting with the top object and remove any code messing with any I/O that is not controlled by that cog (reading is not a problem, no mater how configured IIRC, all cogs can "see" the state of a pin at any time) do the same for all other cogs you are running. This one has gotten me a couple of times.
  • dayoade wrote: »
    You still haven't posted the whole code. If we cannot recreate the issue, we can't do better than stare at the code you have
    provided, which isn't where the problem is I suspect.
    The djnz instruction works, trust me on that...
  • Mark_T, it looks like dayoade did post all of his code in his last post. I believe Frank is correct that the Spin cog and the Pasm cog are driving some of the same pins. The Spin code contains the following lines:
    and the Pasm code contains
    So both cogs are driving ins 21 to 24. If one of the cogs writes a 1 to the output pin the other cog will have no control on that pin. The LED should be moved to separate pins, or the cogs need to coordinate their outputs on each common pin so they are fighting against each other.
  • dayoade updated the posting I think, I couldn't see anything but the PASM without an ORG directive when I looked.
    Yes, as usual posting the whole program allows the real issue to be quickly identified.
  • jmg wrote: »
    dayoade wrote: »
    I always get a number less than the amount of pulses I set it for, but never the same amount. For example, if i set it to five, i would get three on the first, two on the second run, four on the third run.
  • This thread has shown there are people willing to help you -- if you'll let them. I live in Hollywood and work around the movie business, so I'm going to paraphrase Jerry Maguire from the movie of that name: Help us help you.
    How: Post your entire program -- not just the fragment that you think is problematic. Clearly, there is an issue beyond that else this would have been solved by now. I wrote a program in a couple minutes that worked exactly as you specify. Did you plug that fragment into your framework to see if it worked for you as it did for me?
    Again... help us help you. Archive your program and attach it to a message.
    edited 2017-07-18 01:47
    ahem - I have learned to avoid responding to these problems that are described so vaguely as clearly the OP can't be bothered describing anything in detail or posting the code in detail, or how the test was performed and measured, or whether he tried the suggestions etc. Perhaps he is too busy on social media to type more than one line each time and paste some code while awaiting a complete solution.
    Jon, can I amend the Jerry Maguire phrase to "no help us, no help yourself, no help at all"
  • While it's not the full version of the test code, it looks like the complete version of the code that the test code was derived from. It's clearly not the easiest to read, but I enjoy puzzles and managed to unscramble it enough to make sense of it.
    It looks like you're reading three bytes from a UM245R USB to parallel FIFO module.
    The 1st byte seems to be a command to either toggle a light on/off, set a new level, or blink a number of times.
    The 2nd and 3rd bytes form a 16-bit word representing the light level or number of times to blink.
    I suspect, as Frank Freedman said, that your Spin code and Pasm code are colliding. You start the Pasm code which sets each output high for 1/2 second, and moves on to the next after 1/4 second. While that is going on, your Spin code continues to read the UM245R, and if datin[0] equals 3, 5, 7, or 9 then the Spin code toggles one of the pins to output a high, which the Pasm code running in another cog is then unable to set low. If datin[0] ever equals 10, then your Spin code waits forever.
    Remember: A pin is an output if any cog sets it to be an output; a pin is high if any cog that has it set to output also has it set high.
    Simplest solution if you just want to see the pins toggle is to comment out everything underneath the cognew, or ensure some other way that the Spin code doesn't interfere with those pins.
    Here's a cleaner, simple, version of your code (untested):
    CON
      FIFO_l   = 0
      FIFO_h   = 7
      FIFO_RXF = 8
      FIFO_RD  = 9
      FIFO_TXE = 10
      FIFO_WR  = 11
      CLOCK  = 12
      DATA1  = 13
      LATCH1 = 14
      DATA2  = 15
      LATCH2 = 16
      DATA3  = 17
      LATCH3 = 18
      DATA4  = 19
      LATCH4 = 20
      MUX1   = 21
      MUX2   = 22
      MUX3   = 23
      MUX4   = 24
      CAMERA = 25
    VAR
      long Command
      long pulsecount
      byte datin[3], dp
      byte cog
    PUB main
      outa[FIFO_RD] := 1
      dira[FIFO_RD] := 1                                    ' output, RD#
      dira[FIFO_WR] := 1                                    ' output, WR#
    ' Digital output communication lines, SN74HC595
      dira[12..20]~~                                        ' set Clock, data lines and latches to output
      dira[21..24]~~                                        ' set analog muxs to output
      repeat 16
        outa[CLOCK] := 1                                    ' clock it in
        outa[CLOCK] := 0
      outa[LATCH1] := outa[LATCH2] := outa[LATCH3] := outa[LATCH4] := 1
      outa[LATCH1] := outa[LATCH2] := outa[LATCH3] := outa[LATCH4] := 0
      cog := cognew(@RR, 0) + 1
      repeat
          repeat until ina[FIFO_RXF] == 0
          outa[FIFO_RD] := 0
          datin[dp] := ina[FIFO_h..FIFO_l]
          outa[FIFO_RD] := 1
        case datin[0]
          2: dtemp1 := dout1 := datin[2] << 8 | datin[1]  ' change lightlevel1
             repeat 12
               outa[DATA1] := dtemp1 & $800
               outa[CLOCK] := 1
               outa[CLOCK] := 0
               dtemp1 <<= 1
             outa[LATCH1] := 1
             outa[LATCH1] := 0
          3: outa[MUX1] := light1status := !light1status  ' toggle light1status, set MUX1 to new status
          4: dtemp2 := dout2 := datin[2] << 8 | datin[1]  ' change lightlevel2
             repeat 12
               outa[DATA2] := dtemp2 & $800
               outa[CLOCK] := 1
               outa[CLOCK] := 0
               dtemp2 <<= 1
             outa[LATCH2] := 1
             outa[LATCH2] := 0
          5: outa[MUX2] := light2status := !light2status  ' toggle light2status, set MUX2 to new status
          6: dtemp3 := dout3 := datin[2] << 8 | datin[1]  ' change lightlevel3
             repeat 12
               outa[DATA3] := dtemp2 & $800
               outa[CLOCK] := 1
               outa[CLOCK] := 0
               dtemp3 <<= 1
             outa[LATCH3] := 1
             outa[LATCH3] := 0
          7: outa[MUX3] := light3status := !light3status  ' toggle light3status, set MUX3 to new status
          8: dtemp4 := dout4 := datin[2] << 8 | datin[1]  ' change lightlevel4
             repeat 12
               outa[DATA4] := dtemp2 & $800
               outa[CLOCK] := 1
               outa[CLOCK] := 0
               dtemp4 <<= 1
             outa[LATCH4] := 1
             outa[LATCH4] := 0
          9: outa[MUX4] := light4status := !light4status  ' toggle light4status, set MUX4 to new status
          10: pulsecount := datin[2] << 8 | datin[1]      ' Run Light Pulsing (Round-Robbin) with Processor 2
              command := 1
              repeat until command == 0
          255: reboot
    DAT                     org       0
    RR
    loop1
                            or        outa, camera_mask           ' turn on camera
                            or        outa, mux1_mask             ' turn on LED 1
                            mov       Time, OnTime
                            add       Time, cnt
                            waitcnt   Time, Delay                 ' wait for ___ seconds
                            andn      outa, camera_mask           ' turn off camera
                            andn      outa, mux1_mask             ' turn off LED 1
                            waitcnt   Time, #0                    ' wait delay
    loop2
                            or        outa, mux2_mask             ' turn on LED 2
                            mov       Time, OnTime
                            add       Time, cnt
                            andn      outa, mux2_mask             ' turn off LED 2
    loop3
                            or        outa, mux3_mask             ' turn on LED 3
                            mov       Time, OnTime
                            add       Time, cnt
                            andn      outa, mux3_mask             ' turn off LED 3
                            waitcnt   Time, #0
    loop4
                            or        outa, mux4_mask             ' turn on LED 4
                            mov       Time, cnt
                            add       Time, OnTime
                            andn      outa, mux4_mask
                            waitcnt   Time, #0
    end
                            cogid      ID
                            cogstop    ID
    LEDS                    long      |< MUX1 | |< MUX2 | |< MUX3 | |< MUX4 | |< CAMERA
    mux1_mask               long      |< MUX1
    mux2_mask               long      |< MUX2
    mux3_mask               long      |< MUX3
    mux4_mask               long      |< MUX4
    camera_mask             long      |< CAMERA
    BlinkCounter            res       1
    ID                      res       1
  • ChrisGadd, I don't have near the hours on this chip that the heaters, JonnyMac and others have, but I also like the challenge. Makes me learn more. Also sorta habitual from my past with 16 years as a tech trainer. Even get em right occasionally. But the OP would do well to pull the latest copy of GEAR, and experiment with it. It seems to do a good job of simulation. And maybe use Dr. Anandakrishnan's TDD concept to incrementally coding the stages of his project to be able to tell when his latest addition has stepped on what may have worked before.
  • JonnyMac wrote: »
    Thanks for your help. I posted the full code on the 14th, I didn't know how to archive the program and attach it to a message, so I just posted it in code tags. I was able to figure it out and the solution is below.
    Although, the pins are being shared on Spin and assembly, I am only firing the pins in assembly. The Spin code was there for troubleshooting. I didn't think it was a conflict between PASM and Spin because I imagine that issue would look like a value stays high for too long (LED stays on for multiple cycles), so if this were the issue, I would expect to have seen high values that stayed high for longer than the intended duration, not values heading low prematurely. Great idea though that really got me thinking!
    I was able to fix the problem. The PASM was firing zero voltage pulses before the non-zero voltage values were set from the external source. I feel foolish for not noticing this sooner. The decrementing variable was working correctly. To fix this, I placed the cognew command after all the light levels were set. Thank you all again for your help.
    ChrisGadd wrote: »
    Wow, Chris. I really appreciate the effort you put in. I was able to solve the problem (see above). Although, now I want to test your code to just to see if it works. Thanks again for your help and I'll update you a bit later.
