Parallax Serial Terminal - Paste
I've been trying to paste a string into parallax serial terminal, but not having any success. If I hit CTRL-V in the input window, the string is pasted to the screen, but the character sent across the serial connection is the CTRL-V, not the pasted text. If I do a right click and select paste from the drop down menu, the text is pasted to the screen, but nothing is sent.
I'm using PST dated 6-9-2011, which appears to be that same as supplied by the latest version of propeller tool (1.3.2). Does it simply not support paste, or am I doing something wrong?
Scott
Scott
John Abshier
I tried that. It sent the carriage return, but nothing else.
I ended up installing "RealTerm", which seems to have a pretty exhaustive feature set, though I still like Parallax Serial Terminal for its simplicity.
Yes. I have used one, but cannot recall which one. The common PC one of years ago) again cannot recall name - another senior moment) allowed reading a file and sending this. This was before the inbuilt windows terminal program killed it off! And then the Windows terminal program was removed.
