FRAM memory
in Propeller 1
So I was turned on to FRAM memory like this: http://www.cypress.com/file/141321/download
Bus-speed writes, doesn't wear out, 151 year retention, good temp specs, not too expensive... It seems perfect, so what am I missing?
... by which time the Propeller 2 will be available (maybe).
And yet there is solar wind. Go figure.
Good point.
By my calculations, a standard aerofoil type propeller would have to be made of flawless graphene and have a diameter less than the nucleus of a helium atom (by definition impossible). It would need to be held in a near infinitely dense magnetic field (also impossible). It would have to be spinning with a tip-velocity of more than 4*pi*c (impossible) in order to get a positive "airspeed" towards the sun. It would have to be 100.00000% perfectly reflective (tricky). Alas the gravitational well caused by such a thing might make such endeavors somewhat unfeasible.
Worth a try though
Don't know about NASA, but The Planetary Society is working on one.
NASA's been all over this.
http://antwrp.gsfc.nasa.gov/apod/ap110128.html
http://antwrp.gsfc.nasa.gov/apod/ap040821.html
http://antwrp.gsfc.nasa.gov/apod/ap150619.html
Wait.. this was about FRAM, how did we get here?
I thought retention was more than 151 years, but I haven't read anything other than a booklet called "FRAM for dummies" that TI sent me. Looked very interesting though.
Uhhh, hmm can't quite remember.....
MAAAAAYYYYBE...
So I guess we can make a SOLAR Propeller.
