Looking for a latching board-to-board connector
kolyur
I need to add some components to my PCB design. Everything is packed in pretty tight and I can't make the board any larger so I'm looking at using a "daughtercard" type system. The add-on board will be small and light (say 1" x 1.5") but I need a way to attach it to the main board. There will only be 5-6 connections across the interface, and I'd prefer for it to be removable. Additionally, the main board is mounted upside down and is subject to some vibration, so the connector needs to have a mechanical latch or screw lock or something similar--I don't want to just rely on a friction fit.
I'm having a hard time finding something that fits the bill. There are lots of latching wire-to-board connectors (Molex SL, KK, etc etc) but hardly any where both components mount to a PCB. A D-sub would work but is way too big. The ones I did find (see photo) are expensive specialty items. I'd prefer something through-hole if at all possible. Any suggestions are appreciated!
