Questions on FLiP
in Propeller 1
First of all, love the name and the palindrome 32123.
From what I can tell, it looks like I can power the FLiP from my normal 5V power supply. Which is awesome. So no need to add voltage regulators to go from 5V to 3K3.
Now, I assume this is power only. The I/O pins are still 3K3 volts. Is this correct?
With P26/27 I feel that LED's on them might cause me problems. I actually need MORE than 32 pins so loosing two pins might be a deal breaker for me. Looks like it would be a chore to remove them. Would using those pins for VGA output or bus input (1 MHz) be an issue?
If I wanted to attach one of those pins to a chip enable pin of another chip...for example...would that be an issue?
If you connect another chip to them, the default settings will be low until the Propeller runs a program to change the I/O settings to something else. This is OK if you connect a true chip enable that turns the chip on when a high signal is present. Many such chips are active low though and will be enabled by default when connected to these pins. Easiest fix would be to use an inverter between the chip enable and these pins.
And you are right about the active low...I was just using an example.
I've told my wife I want one of these for my birthday. But looks like they may be hard to obtain later.
Thanks everyone!
Fear not! They will make more!
Connect to 5-9Vin? Is it a low dropout regulator? What's the overhead voltage?
erco - Congrats! Can't wait to see what you build - I believe the answers are here - 32123-Propeller-FLiP-Module-Guide-v1.1.pdf
Erco- your the man ready for this... You'll need Li-ion twins.
In theory the absolute min vin is 4.5V, plus a load dependent diode drop of about 260 to 400mV. Keep above 4.8V ideally.
