Sharing locks between PASM and Spin
in Propeller 1
Hello,
I'm trying to share a lock between a SPIN and a PASM cog.
PASM code:
Spin code:
c_sem and sem contain the same values.
It seems like the Spin part does not clear the lock, because the PASM cog is stuck forever. When i remove the lock-code from the Spin code however, the PASM code works as expected.
The PASM loop takes 10_000 cycles.
Does anybody have an idea what could have gone wrong?
Thanks!
PASM code:
:loop waitcnt asm_cnt,asm_cycles 'wait for next CNT value (timing is determinant after WAITCNT)
call #S_Lin2Alaw
mov pbuf, par_x
cmps counter, #16 wz
if_z call #setFlagBufA
cmps counter, #16 wz, wc 'setFlagBufA overwrites c so we have to cmp again
if_z_or_c jmp #:write 'counter <= 16 -> write
cmps counter, #32 wz,wc
if_z mov counter, MAX_VAL 'counter == 32 -> counter:= 0, set flag
if_z call #setFlagBufB
:write add pbuf, counter
wrbyte aval, pbuf 'write byte to buf
adds counter, #1
call #S_Alaw2Lin 'in:aval out: r1
jmp #:loop
setFlagBufA
:l lockset c_sem wc
if_c jmp #:l
wrbyte _1, c_flag '1 means a is full
lockclr c_sem
setFlagBufA_ret ret
setFlagBufB
:l lockset c_sem wc
if_c jmp #:l
wrbyte _2, c_flag '2 means b is full
lockclr c_sem
setFlagBufB_ret ret
Spin code:
repeat while(True)
waitcnt(2_000_000 + cnt)
repeat until not lockset(sem)
temp := flag_buf_full[0]
if (temp <> 0)
prinarr(@flag_buf_full, 1, string("flag_buf_full="))
byte[flag_buf_full] := 0
lockclr(sem)
Thanks!
repeat while(True) waitcnt(2_000_000 + cnt) repeat until not lockset(sem) temp := flag_buf_full[0] byte[flag_buf_full] := 0 lockclr(sem) if (temp <> 0) prinarr(@temp, 1, string("flag_buf_full="))That's exactly what I just tried. prinarr and some other function that is called while the lock is held were taking too much time. It's working now.
Thank you!
