saving on EEPROM
in Propeller 1
Hi Everybody. so I have a propeller mini and a propeller project board. I ran the eeprom test file in my learn folder on the project board and everything worked fine but when I try to run it on the mini nothing happens I even changed the address below 32xxx which worked fine on the project board but nothing on the mini. is there something different about the mini?
Most likely would help. That is a pullup resistor.
