Simpletools pause() function
JonnyMac
in Propeller 1
I am starting to work with Propeller C and found that the pause() function can be tripped up with large values.
May I suggest it be recoded like this:
void pause(int time) // pause function definition
{ // If st_pauseTicks not initialized, set it up to 1 ms.
// if(!st_pauseTicks) set_pause_dt(CLKFREQ/1000);
long t0 = CNT;
while (time--) {
waitcnt(t0 += st_pauseTicks);
https://github.com/parallaxinc/Simple-Libraries/issues
And slow down, as I'm still trying to understand the Real Time Clock app that you built in Blockly!
