Prop Tool Sucks.
Heater.
My apologies for the inflammatory thread title but in this case it is literally true. The Propeller Tool is sucking over 30% of my CPU performance even when not doing anything!
As I'm travelling in the USA just now I noticed that the battery life of my Surface Pro 4 seemed rather short. Then I started to wonder why the the thing is getting rather warm all the time. I put this down to my habit of having a ton of tabs open in Chrome, no doubt with their Javascript churning away doing whatever they do.
Today it bugged me enough to open up the task manager and see what was happening. To my surprise the Propeller Tool is top of the list consuming over 30% of my CPU and hence battery life!
This is a big surprise because:
1) There is no sign anywhere else that the Prop Tool is even running.
2) As far as I recall since I fired up the Prop Tool last this machine has been restarted, upgraded, power cycled...
Anyone else seen this problem?
I can live with the Prop Tool getting wedged and draining performance but when there is no sign of it even running, except in the task manager, that is a bit of an issue.
When I get a free moment I will play with this again. Start the Prop Tool, sleep, reboot, etc, and see what happens.
Maybe its Chrome sucking the battery?
It's been fine for me for years...
It does crash sometimes when accessing removable media though...
Neither do I have to boot all the time due to Chrome memory usage.
Just now I have 19 tabs open in Chrome. That and a couple of other apps use 60% of memory. CPU usage is 3%. Most or which is the Window Manager and Task Manager!
The culprit was the Prop Tool. As shown in the screen grab above.
I suspect this is some weirdness to do with the Surface going to sleep or some such.
Still wouldn't explain the CPU load, since PropTool usually does not run long enough while compiling to produce CPU load.
But you start me thinking....
Last time I used the Prop Tool this Surface was connected to my Samsung monitor. Both monitor and surface screen were is use.
In that situation it's a lottery as to which screen applications open. Or which screen they will pop up dialogues. It's a mess.
So, it's possible the Prop Tool was displayed in a position that should be on my Samsung screen, which is not here. So I could not see it.
That does not account for the CPU usage though.
Interesting indeed. I can't replicate it.
I have to find time to try and reproduce this.
Question is, what are the operating system and applications up to?
I have never had that many tabs open at one time. How do you manage that many? Let alone the computer keeping up.
I have more than once ran into the 'max 255' X Windows window limit.
WOW You must have an impressive setup. I would never have imagined that was even possible.
The only difference in the two setups is that on my personal tablet I have a 64G microSD card in the socket and I've configured windows 10 to put my Documents, Pictures, and Music files on it instead of on the onboard flash. Most applications work fine with that, and considering the tiny amount of data PropTool uses compared to a music player or full word processor, it's hard to see why it would have a problem, but it does. I'm sure it's not anything chip did "wrong." I've had similar issues in my Windows software over the years because of undocumented Windows Smile. You would laugh yourself silly to see how much code it takes to open a serial port in Windows through the API, a one-line-of-code operation nearly everywhere else.
And it does it with only 30% CPU load. Just make sure you hibernate your system instead of shutting down
But don't worry!, what PropTool doesn't do in this machine is overtaken by Quartus and Diamond, they like to start as zombies or zombify themselves at the drop of a hat...
I have like 50 Tabs in 4 windows of Opera
My reported problem seems to be a rare occurrence. I have not managed to reproduce it since.
I get the feeling it's something to do with Win 10 on the Surface Pro going to sleep and resuming badly or some such.
