In search of a gland
                    Guys, i am sure you have used one. at least one of you....
I am looking for a gland that i can pass a USB Type-A male through into a box and then tighten the gland down to keep the box watertight. looking for something affordable. I have seen the $70 ones. Any ideas?
Once inside the box you can use a small adapter to go back up to the humongous Type A connector.
https://www.polycase.com/cg-series
Someone mentioned Elecdirect to me recently, but I have never used them:
http://www.elecdirect.com/catalogsearch/result/?q=gland
http://www.neutrik.com/en/multimedia/multimedia-connectors/usb/
http://www.newark.com/bud-industries/ng-9511/cable-gland-clamp-pg7/dp/83F3332?ost=83F3332&searchView=table&iscrfnonsku=false&ddkey=http:en-US/Element14_US/search
Jim
And thank goodness this thread wasn't about Chinese organ harvesters. "I woke up in a bathtub full of ice and read this note..."
That's a new word for me to. Where did it come from? Sweat gland maybe, like an open or closed pore. Funny word to be used in electronics.
Of course it helps to qualify it as "cable gland". To avoid confusion
Anyway, thanks for the suggestions. Just so happened I suddenly have need for such things here this week.
ROFL!!!
https://en.wikipedia.org/wiki/Stuffing_box
From the dictionary:
ɡland/
noun
plural noun: glands
a sleeve used to produce a seal around a piston rod or other shaft.
Origin: early 19th century: probably a variant of Scots glam ‘a vice or clamp’; related to clamp.
That may explain it. You Brit's have very descriptive words for things:
One technician said to another, "give me that bloody gland".
The British have such a way of expression, could have caught on from someones slang use.
EDIT: Just seen Dave's post, further proof it came from that side of the pond.
I would guess that most of us on this forum have not dealt with steam engines and other early 20th century machinery so in the context of this forum it is a new word to us. For myself, having started in the medical side of computers and instrumentation the first reaction to seeing it was along the lines of what erco posted.
And about those one-syllables that end in "am": almost every letter of the alphabet can be used to precede it, viz:
am
bam
cam
dam
e
fam
gam
ham
i
jam
k
lam
ma'am
Nam
o
Pam
QAM
ram
Sam
tam
u
v
wham
x
yam
zam (after sha)
Well, at least the guys at Platt Electrical in San Jose https://www.platt.com/search.aspx?q=glands
@DaveJenson ,
In this politically correct world are we still allowed to say "stuffing box"? So many good old engineering terms seem to be off limits today, for example "ball cock".
No ever accused me (or Wikipedia) of being politically correct!
Green eggs and ham, Glam-I-Am?
Not in a box, not with a fox.
Not in the rain, not on a train.
It's not my will, I tell you Phil!
Sorry, nothing that large in my stuff. However, have you looked at the USB male A connectors with solder cups so you can cut, feed through a small gland, then solder on the connector?
Over many many years of working with mechanical, hydraulic, pneumatic, steam, and vacuum hardware I don't recall ever having the parts that keep the stuff inside from leaking to the outside (or vice-versa) called anything but seals or o'rings. Glands was a new one for me.
Is "gland" perhaps referring to a specific type of seal?
In good old steam engines and pumps one has a hole through which a shaft has to travel. The gap between the hole and the shaft being filled with some graphite, some fiber, rubber, whatever, packed in there. In order to stop that sealing stuff from falling out it is rammed in and held in place with some screw/nut arrangement that tightens p on it.
In modern day electrical things cables pass through holes in boxes and get sealed with a similar arrangement of a packing material and something to screw it in tight.
I think "gland" refers to that whole assembly. The threaded parts, the sealer inside, etc.
Where as "seal" or "o'ring" is just that bit in the middle that is doing the actual sealing.
https://en.m.wikipedia.org/wiki/Cable_gland
Platt Electrical has been selling all over the USA since 1953 and they sell "cable grands"
https://www.platt.com/platt-electric-supply/Strain-Relief-Cord-Grips/Cable-Glands-Non-Metallic/search.aspx?SectionID=9&GroupID=121&CatID=856
A cable gland is not any kind of "cable connector".
