_CLOCKMODE=RCSLOW 'actual speed / power determination?
CounterRotatingProps
A search on "RCSLOW" returns an overwhelming set of results, so apologies for asking a basic, remote-telemetry question here ...
Up to this point in my Propellerness, I've not needed to mess with the clock, but now have two different new projects that do. One requires the low power of spinning down the prop as far as possible, but also needs ( the contradiction of ? ) precision timing. The other needs some sort of watch dog to wake it up. I'd prefer not to add to the external part count unless there's no other way.
The two problems:
1) When running in RCSLOW, the application needs to determine its actual rate. The Prop Man says the clock "may be 13KHz to 33KHz." Since this is the prop's fundamental baseline clock rate, I'm thinking prop code is unable to determine internally its actual running speed. RIght ?
[EDIT]: I've noted the XINPUT option, but that's more parts - maybe still the only way?
2) Re watch dogging - the system CNT, or one of the two a cog counters, do not / can not run standalone. Right? (CNT considered more below.)
Project 2 has to be fully asleep for long periods (hours to days) and then quickly (reasonably) blast off to full-tilt 80MHz. I could stop all cogs but one and have it do cascading waitcnt()s, but I'd rather put it to sleep.
Is there a way to do this without an external RTC which would whack it awake ?
Using the waitcnt() approach, I'm trying to figure out how hungry the hibernating prop will be ... If just one cog is watch dogging, then, according to the Prop Man, usage would be:
So, would I then take 7/8 of that 10mA, to arrive at a total of about 1.25mA total while "sleeping" ?
(Granted, a bit more would be used when the counter cascades and reloads, but I don't think that would amount to much.)
thanks for the assist!
The two problems:
500uA per MIP, where a MIP := (Clock) Freq. in MHz / 4 * number of active cogs.
:= 500uA * 80Mhz / 4 * 1
:= 10 mA
But the Man also says that during waitcnt(), the wait hardware reduces the cogs consumption to 7/8ths of its normal power.:= 500uA * 80Mhz / 4 * 1
:= 10 mA
Internal clock ignored here:
When using an external crystal or resonator, the slowest possible clock speed is the fundamental frequency of that crystal / resonator itself. Right? So, if the Xtal is 5MHz, that's when I'd use the PLL1X for 5Hz, as you say; and PLL16X for 80 MHz, right?
Is this resulting power-draw calculation correct :
500uA / MIP, with 1 cog in waitstate @5MHz, the prop would need only a paltry 78.125 micro amps.
(500* (5/4*1 ) ) / 8 = 78.125 uA ?
The real information is the manual (especially pgs 28-30, and 69), and the datasheet (pgs 26-28).
You will need to measure this, as the XTAL osc itself has a significant current draw, I'd guess rather above 78uA
In another thread, this post
http://forums.parallax.com/discussion/comment/1410512/#Comment_1410512
has quite a nice looking WDOG element/timer. TPL5010 has 10's of nA run and ~1% precision, which is very good for 1uA/sub-uA OSC
If you need better precision waits, and lowest power, then a RTC is likely to be needed.
You can clock the Prop from a 32KHz RTC CLKOUT, for some middle ground smarts, if needed.
(Note: see corrected version five posts down. Pertains to current in RCSLOW mode, where it should read around 10µA not 80µA.
The XLS includes pasm versions, and, draw added by a cog counter.
I'm often running off batteries or harvested power, so excess microamps matter.
Note: see corrected version below. Pertains to the current when clkmode=RCFAST and the output pin is toggling.
Nice tables and data
I'm curious about the Icc change on pin toggle, at low frequencies, that seems quite high ? - was the pin driving something else.
A purely digital pin, no load, no pullups, should have a
CPD power dissipation capacitance ~ Sum(CL * VCC^2 * ftog)
eg 10kHz toggle into 30pF (guess) is 2.7uA of added CPD, or 5MHz into 30pF is + 1.35mA
http://forums.parallax.com/discussion/129731/prop-limbo-how-low-power-voltage-can-it-go
