Parallax FLiP Schematic ?
I see the Propeller FLiP microcontroller module is taking pre orders.
Is there a link to the schematic anywhere ?
I want to check did Parallax remember to support (optional) hardware handshake lines, to the FT231X, to allow higher speeds ?
32123-Propeller-FLiP-Rev-A-Design-Files-20170505.zip
Seems there are no hardware handshake lines connected, not even optionally.
Perhaps they can be added on the next board revision ?
I see the oscillator is SIT8918BE-13-33E-5.000000G
The first “3” is for ±50 PPM, ( SiTime make down to ±20 PPM ) but the data suggests typically they are better than that ±50 PPM
A useful example project would be to run
http://forums.parallax.com/discussion/123170/propbasic-reciprocal-frequency-counter-0-5hz-to-40mhz-40mhz-now
connected to the Parallax GPS module 1pps, and store the result into high-eeprom, so as to ship an Osc calibration value with each PCB ?
One beef I have is with Q201, the reset transistor. That should really be a digital transistor, rather than a generic MBT3904. A digital transistor fits in the same footprint and then doesn't need R201, but it adds a resistor in series with the base. As shown, capacitor C202 is tied directly to the base, and the reset signal can be very ugly with oscillations. Probably doesn't matter in most cases, but we've had suspicions, and I'd just prefer a clean reset pulse.
For Learn 'ing Propeller?
Fun Lov 'in Propeller?
