UCC27322 with pictures!!!
in Propeller 1
Notice the description at the bottom about PGND..."Grounds are separated to minimize ringing affects due to output switching...."
What does this mean? ... that we don't hook all grounds together or that we do our best to keep them as far apart as possible?
I have been assuming that I just keep them as far apart as possible, but the diagram doesn't look like it has a common ground.
I think I understand it... but I want to be sure.
I'm driving an FET (IRLB8743) with the UCC27322, am I correct in assuming that the same source can be used for the UCC27322 and the drain of the FET?
Rich
Rich
all without injuring the P1's pins:)
